RFID medicine teller!! problem with programming
Results 1 to 23 of 23
    freqout porta.5,1000*/$100,115*/$100
    If I am doing my math correctly the above code is trying to produce a -256Hz tone for 1 second. I do not think this is possible
    Try:
     FREQOUT PORTA.5,1000,440,350
    and see what happens.
    Nov 2008
    Post
    define LOADER_USED 1
    define OSC 4
    define LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    adcon1 = 7
    trisa = %11111111
    hour    var     byte    ' Define hour variable
    dhour   var     byte    ' Define display hour variable
    minute  var     byte    ' Define minute variable
    second  var     byte    ' Define second variable
    ticks   var     byte    ' Define pieces of seconds variable
    update  var     byte    ' Define variable to indicate update of LCD
    i       var     byte    ' Debounce loop variable
    cl var byte
    buf var byte(10)
    tagNum var byte
    idx var byte
    char var byte
    tag1 data "0010828978"
    @       device WDT_OFF
            CMCON = 7       ' PORTA digital
            Pause 100       ' Wait for LCD to startup
            hour = 00        ' Set initial time to 00:00:00
            minute = 00
            second = 00
            ticks = 00
            update = 1      ' Force first display
    ' Set TMR0 to interrupt every 16.384 milliseconds
            OPTION_REG = $55        ' Set TMR0 configuration and enable PORTB pullups
            INTCON = $a0            ' Enable TMR0 interrupts
            On Interrupt Goto tickint
            PORTB = 0       ' PORTB lines low to read buttons
            TRISB = %11001111       ' Enable buttons
    ' Main program loop - in this case, it only updates the LCD with the time
    mainloop:
            ' Check any button pressed to set time
            If PORTa.0 = 1 Then decmin
            If PORTA.1 = 1 Then incmin
            bbb:
            if porta.2 = 1 then nice
            ' Check for time to update screen
    chkup:  If update = 1 Then
                    Lcdout $fe,1   ' Clear screen
                    'lcdout $FE,$c0,"Next 12:10:00"
                    ' Display time as hh:mm:ss
                    dhour = hour    ' Change hour 0 to 12
                    If (hour // 12) = 0 Then
                            dhour = dhour + 12
                    Endif
                    ' Check for AM or PM
                    If hour < 12 Then
                            Lcdout dec2 dhour, ":", dec2 minute, ":", dec2 second, " AM"
                    Else
                            Lcdout dec2 (dhour - 12), ":", dec2 minute, ":", dec2 second, " PM"
                    Endif
                    update = 0      ' Screen updated
            Endif
            lcdout $FE,$c0,"Next 12:10:10 AM"
            if (dhour = 12) and (minute = 10) and (second = 10) then  aaa
            goto mainloop
     aaa:
     'freqout porta.5,1000*/$100,115*/$100
     sound porta.5, [200,100]
     lcdout $FE,1,"please"
     lcdout $FE,$c0,"Medicine!!"
     high portc.0
     update = 1
     'pause 2000
    goto mainloop
    nice:
    high porta.3
    low portc.0
    high porta.3
    'pause 3000
    serin2 portc.7,84,[str buf\10]
    'nextline:
    for tagnum = 1 to 2
    for idx = 0 to 9
    read(((tagnum-1)*10)+idx),char
    if(char<>buf(idx)) then goto bad_char
    next
    goto tag_correct
    bad_char:
    next
    bad_tag:
    low porta.3
    'pause 500
    high portc.0
    tagnum = 0
    lcdout $FE,1,"Sorry,Wrong"
    'pause 3000
    lcdout $FE,1,"Please Take"
    lcdout $FE,$c0,"Medicine A"
    goto nice
    tag_correct
    low porta.4
    high porta.5
    freqout porta.5,2000*/$100,880*/$100
    lcdout $FE,1,"Correct take"
    high portc.3
    second = second + 1
    pause 3000
    goto mainloop
            'Goto mainloop   ' Do it all foreve
    ' Increment minutes
    incmin: minute = minute + 1
            If minute >= 60 Then
                   minute = 0
                    hour = hour + 1
                    If hour >= 24 Then
                            hour = 0
                    Endif
            Endif
            Goto debounce
    ' Decrement minutes
    decmin: minute = minute - 1
                    minute = 59
                    hour = hour - 1
                    If hour >= 24 Then
                            hour = 23
                    Endif
            Endif
    ' Debounce and delay for 250ms
    debounce: For i = 1 to 25
            Pause 10        ' 10ms at a time so no interrupts are lost
            Next i
            update = 1      ' Set to update screen
            Goto chkup
    ' Interrupt routine to handle each timer tick
            disable         ' Disable interrupts during interrupt handler
    tickint: ticks = ticks + 1      ' Count pieces of seconds
            If ticks < 61 Then tiexit       ' 61 ticks per second (16.384ms per tick)
    ' One second elasped - update time
            ticks = 0
            second = second + 1
            If second >= 60 Then
                   second = 0
                    minute = minute + 1
                            minute = 0
                            hour = hour + 1
                            If hour >= 24 Then
                                    hour = 0
                            Endif
                    Endif
            Endif
            update = 1      ' Set to update LCD
    tiexit: INTCON.2 = 0    ' Reset timer interrupt flag
            Resume
    code shown on top is my program code. i want to know how to let real time work continuing when the time is match which what the time i was setted. because i has foind out the problem when time is matched. the real time will stopped it there.
    Not sure...but I think the code might be hanging here
    I do not see anything else at the moment.
    goto nice
    tag_correct
    low porta.4
    high porta.5
    high portc.3
    second = second + 1
    pause 3000
    goto mainloop
    Nov 2008
    Post
    erm.. i has following your instruction, but still remain same thing happening. athrough i ignore the frequency the time still might stopped when the time is matched with the time i setted.
  1. 16F676 programming problem
    Last Post: - 18th May 2009, 17:39
  2. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 04:21
  3. bh 1415f and picbasic problem
    By patricx in forum Off Topic
    Last Post: - 18th September 2007, 22:19
  4. Programming Problem with PIC16F819
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 24th July 2007, 18:42
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 00:02
