Change On Interrupt, PIC16F884
Results 1 to 18 of 18
    Quote Originally Posted by elec_mech View Post
    Ahh, I was wondering if that might impact it. So, an external interrupt will not interrupt the program while executing a pause command? Is that due to the way PBP works? If I were to go so far as to program in assembly, it's been a while, I would assume I could interrupt a timer function with an external interrupt. Okay though, I see what you mean.
    Alright, I gave it shot and eureka, it works! Thank you Bruce! Here's the updated code.
    It's due to PBP interrupts being a Psudo interrupt, it detects the hardware interrupt, puts a request on the stack and waits for an opportunity, Whereas an assembly interrupt is like cops, break in and announce it's arrival.
    Apr 2005
    Virginia
    Question Multiple Resumes not working
    Joe, thanks for the info!
    Okay, related to interrupts, I've run into another problem. I go into my interrupt routine, detect a button on a port change and then tell the program to resume at a new routine based on which button was pressed. The first button works fine, but whenever I press the second button, it seems to ignore/skip the resume (colored below) and go on to the end of the interrupt routine. I added a toggle to an LED to indicate where the program was going. It works before the colored resume statement and after the end if statement, but not immediately after the resume statement. I also tried it at the beginning of the Score_player2 routine, which of course didn't work. I tried a quick search on the forum, but didn't come across anything similar, at least not yet. Any reason PBP would skip or ignore a resume statement? I've just included the interrupt routine - the rest is very similar to the code posted above.
    I don't know if this is an indication of another problem, but I'm multiplexing two seven segment digits and whenever I press either button, one of the digits goes out, sometimes digit A and sometimes digit B regardless of the button pressed, and comes back on whenever I release the button.
    DISABLE ' do NOT place interrupt checking code below
    Halt: ' Halt Routine
    temp = PORTB
    TOGGLE PORTE.1
    IF temp.0 = 0 THEN
    WHILE PORTB.0=0 ' wait for button release & end mismatch condition on portb
    WEND
    PAUSE 20 ' Debounce delay
    INTCON.0 = 0 ' Clear the interrupt-on-change flag
    RESUME SCORE_PLAYER1
    IF temp.1 = 0 THEN
    WHILE PORTB.1=0 ' wait for button release & end mismatch condition on portb
    WEND
    RESUME SCORE_PLAYER2
    RESUME Main ' Go to Main routine
    ENABLE ' Enable all active interrupts
    Not a good idea to me to use label with RESUME as you never know where the program was before to jump in the ISR. You should jump (goto) at the end if your ISR, then your program will return where he was before.
    Apr 2005
    Virginia
    Thumbs up
    Steve,
    I'd be lying if I said I completely understood what you meant, but I noticed that I was forcing the program to resume at the start of the Main routine and allowed it to just resume at the end of the ISR. It works! Thank you for your advice. I still have one of the digits going off whenever I press a button, but I'll investigate that further. Likely a hardware issue.
    temp = PORTB
    TOGGLE PORTE.1
    IF temp.0 = 0 THEN
    WEND
    IF temp.1 = 0 THEN
    WEND
    RESUME ' Resume program running before interrupt occurred
  1. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 20:53
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  3. Can't ID interrupt source with this IntHandler??
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
