Move seperate bytes into a word
Results 1 to 19 of 19
    Default 4 bytes RAM, 4 instructions to convert
    OK - here's a little smaller verion...;o}
    Z VAR WORD BANK0 ; use BANKA for 18F part
    A VAR Z.LowByte
    B VAR BYTE BANK0
    C VAR Z.HighByte
    D VAR BYTE BANK0
    A=%00000001
    B=%00000010
    C=%00000011
    D=%00000100
        CHK?RP _Z
        swapf  _B, W     ; swap nibbles in B, result in W
        iorwf  _A, F     ; or with A, result in A (low byte is done)
        swapf  _D, W     ; swap nibbles in D, result in W
        iorwf  _C, F     ; or with C, result in C (HighByte is done)
    Z = %0100 0011 0010 0001
    Last edited by Bruce; - 12th November 2008 at 09:29. Reason: Force vars into same bank
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bombay, India
    Wow! What compact and fast code! Both Bruce and DT must have been coding in Assembler for ages to have such skill I might have coded it like Steve(mister_e) here and just got the job done. But, I guess, this is how compiler writers optimize their code generation capabilities. I would like to hazard a thought that this kind of optimisations would help PBP generate tighter code.
    That's why we don't have optimization contests for money around here...
    Bruce would always win.
    SWEET!<hr>
    Ioannis,
    The CHK?RP macro just changes the bank to where the specified variable is located. That way you don't have to keep track of where everything is. You can let PBP handle the banking, even though it's ASM.
    And yup, wading through the library is about the only RTFM.
    It's in the PBPPIC14.lib file for the 12F and 16F's.
    Thanks Darrel. But if the macro had to change the page, how will it restore backe the original page? It isn't called again. Is this done automatically?
    PBP will handle it for you on the next PBP command.
    Oh, I see. OK, Thanks Steve.
    There is another macro that resets it to bank0 ...
        RST?RP   ' Reset to Bank0
    The ASM statement uses that macro to set the bank to 0.
    So when you enter an ASM block, you always know you're starting off in bank0.
    The ENDASM does not reset to bank0, but as long as you use PBP's banking system and don't change it manually, then after you exit the ASM block, PBP knows what bank you changed to, and will be able to continue on.
    If you do GOTO's or BRA's in the ASM block, you have to be more careful, because PBP's banking system can't follow the jumps. It's up to you to make sure the banks are correct before jumping.
    If the banks are changed manually without PBP's assistance, then you have to reset the bank manually before exiting the ASM block.
        banksel 0
    PREVBANK = 0
    hth,
    Last Post: - 14th June 2016, 07:55
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  5. calculation problem
    Last Post: - 31st March 2006, 15:23
