16f785
Results 1 to 5 of 5
Thread: 16f785
    Omaha, Nebraska USA
    Question 16f785
    Does anyone have comments or experiences to share about using the op amps in the 16F785?
    I have an application in mind, and using the 785 would eliminate a lot of glue.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    I had, worked great for me on some kind of feedback control and few audio gizmo. Having their output directly connected to ADCs input (and comparator) is somehow useful, this also give you an external test point.
    The two phase PWM was also a nice feature for me.
    No bad comments on them from me.
    Omaha, Nebraska USA
    What I'd like to do is cascade the op amps, then use the two comparators as a window detector.
    Russ
    Just look how they're internal connected, I don't think it will be 100% doable, but probably close enough. Sure comparator interrupts are handy, while sometime a couple of ADC reading would do... it really depends of the final application and timing i guess.
    Omaha, Nebraska USA
    Thanks for the suggestion. I looked again at what I actually need, and I may have been over-thinking the analog side of the application. Now, I think maybe I should just send the output of the cascaded op amps to an ADC pin and set the limits of the "window" digitally.
    Russ
  1. Opamps in the 16F785.
    By Ingvar in forum mel PIC BASIC Pro
    Last Post: - 12th October 2007, 08:32
