PIC to Relay
Results 1 to 15 of 15
Thread: PIC to Relay
    Jun 2007
    Mansfield, UK
    Ok, heres that schematic. Im sorry its not the best looking one ever. I did it in M$ paint :P
    The lefthand side of the optoisolator works exactly the same as an LED. Check the datasheet for the specific one your using for the voltage. Usually i put a 1K resistor between it and the PIC. I always put a 1K resistor between the opto and the G pin of the triac too although i cant remember why (maybe someone else can clarify this bit).
    It may or may not help you but ive included a circuit that i designed to control 4 lights using triacs. I usually find that a PCB layout helps me more than a schematic so you have both just incase. The triac im using is a "BTA08-600B 8A 600V" and the opto is a "MOC3020M". Both resistors either side of the optos are 1Ks. I have a few of these circuits connected up and working perfectly
    May 2008
    Italy
    I think useful to add the attached schematic for all who want to use TRIAC for their ac application.
    Remember that the triac side is always connected to the main. Be very careful !!
    Al.
    Oct 2008
    Red face
    OK cool!! Im taking a look at the triac now. For the solid-state, isn't there a "flyback" diode required?
    Omaha, Nebraska USA
    Quote Originally Posted by aratti View Post
    I suggest the upper schematic. You might be happier with a MOC3033 or other MOC303x. You'll also discover that the 180 ohm resistor is not necessary.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. HELP ME, SMS controlled relay using PIC
    By pazko1125 in forum mel PIC BASIC
    Last Post: - 2nd October 2008, 15:26
  2. Pic to relay
    By ruijc in forum General
    Last Post: - 8th November 2007, 19:03
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
  4. Replies: 22
    Last Post: - 9th April 2007, 15:25
