I best leave the choice of transistor to someone else because im not an expert with those. I can help you with the rest though. A standard 1N4001 1A 50V rectifier diode has always worked fine for me when using relays/solenoids etc.
You could use a triac instead of a relay too. It eliminates the annoying clicking sound and enables you to control the brightness if you want to take it that far
