SSPCON and 18F2431 Problem
Results 1 to 5 of 5
    Nov 2008
    Default SSPCON and 18F2431 Problem
    i am trying to use the SSPCON Reg. on a 2431, but the compiler tells me that its a bad data type. I saw the definition is missing in the "PIC18EXT.Bas" File.
    I added the "SSPCON VAR BYTE EXT" definition. But after that i get the error message "...Symbol not previously defined (SSPCON)" in pbppic18.lib.
    Can some one help?
    Ralf
    which version of PBP and MPASM you have? Sometimes it's a MPASM problem...
    SSPCON VAR BYTE EXT worked for me directly in the code, also worked for me when modifying PIC18EXT.BAS file...maybe you just forgot to save the file after doing the modification, or SSPCON register definition is also missing in the MPASM file ?
    Quote Originally Posted by ... \MPASM Suite\P18F2431.INC
    ADRES EQU H'0FC3'
    ADRESL EQU H'0FC3'
    ADRESH EQU H'0FC4'
    SSPCON EQU H'0FC6'
    SSPSTAT EQU H'0FC7'
    SSPADD EQU H'0FC8'
    Nov 2008
    Steve,
    sure i saved it! The define is also present in the inc file.
    I use PBP 2.508, MPASM is 5.20.
    If you're using MicroCode Studio, make sure you manually direct MPASM folder to the default c:\program files\Microchip\Mpasm Suite
    Works a treat here
