PULSIN for frequency meter?
Results 1 to 10 of 10
    Question
    BPB calculates with 16 Bits ... Ok ???
    100 000 Hz @ 1 bit resolution need ???
    That's it ...
    why do not use the timer ?
    For low frequency is more accurate measure the period.
    Dec 2005
    If using the PIC as the frequency generator, wouldn't it be simpler to calculate the frequency rather than measure it?
    Dec 2007
    Alain> I don’t follow your discussion, sorry.
    GioppY> Could you give more detail please?
    Dave> I guess I was unclear about the use of the PIC, the PIC is not involved in the generator part.
    Thanks!
    Check you PIC datasheet, some have built-in counter. This allow you to use them to count the incoming pulses for a x sampling time.
    A while back i've made this one
    http://www.picbasic.co.uk/forum/showthread.php?t=1044
    Maybe this could be handy for you. It use TIMER0
    Dec 2007
    So, what you mean is that the PULSIN command is not the way to go then?
    Thanks.
    Lightbulb
    And now the question; is this achievable using a 16FXXX device and the PBP PULSIN command?
    a 16F device running @ 20 Mhz max... so PULSIN will give you 2µs per count.
    PBP 16F compiler uses 16 bits ... so, 65535 counts at a maximum
    Pulsin will give you a valid result from 1 to 65535 unit +/- 1 count.
    @ 50% duty cycle your period can be ... 4 to 131070 µs +/- 4µs
    a 16F device running @ 4Mhz ... so PULSIN will give you 10µs per count.
    @ 50% duty cycle your period can be ... 20 to 655350 µs +/- 20µs
    from that you can understand what precision and resolution you can get with the PULSIN command.
    That's quite simple ...
    PS: Gioppy gave you ... half of the answer !!! LOL
    Have a look here:
    http://www.picbasic.co.uk/forum/show...69&postcount=4
    You can use this code to measure the frequency with timer1. This open the timer1 gate for exactly 1 sec. (@4MHz); so you can get a resolution of +- 1Hz. The result return in 2 words Hicntr and Locntr. Obviously you need a routine that convert the 32 bit to decimal.
    With a bit less accuracy can be done in pbp.
    http://www.picbasic.co.uk/forum/showthread.php?t=7828
    Not very easy, but works fine.
    Gianni
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  4. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 14:52
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 15:45
