PIC && WiFi suggestions
Results 1 to 23 of 23
    Dec 2005
    Default Re: PIC && WiFi suggestions
    Quote Originally Posted by jellis00 View Post
    Thanks so much, Dave, for this info. I checked out the MiniSocket from ConnectOne and have a couple of questions:
    1. It was added to the PicBasic Forum - Communications section a few days ago. Here's a direct link to mackrackit's code.
    2. It probably came from conflating the values you cite in a quick scan of the product brief.
    3. They are usually quite prompt in response.
    4. mackrackit's code cited above will serve as well as anything else. The AT commands are the same although there may be differences in details and configuration.
    As I noted recently in another thread I usually use ZBasic for projects that need more than 8 pins. It nearly eliminates development time and can cost as little as $10 for the smallest of their chips. However, I don't believe there's any way to put their chips to sleep in a really low drain mode. You can with a PIC but I believe you need to use the ASM sleep commands to do this. It's been too long for my feeble old brain to recall details and I lost a network HDD that had nearly all of my older projects a few months back.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 03:19
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. PIC Suggestions
    By Tobias in forum Off Topic
    Last Post: - 7th January 2008, 06:04
