PIC && WiFi suggestions
Results 1 to 23 of 23
    Oct 2008
    Default PIC && WiFi suggestions
    I want to experiment with getting a PIC to send some simple data wirelessly to a PC.
    google [ pic xbee] brings up many sites yet think some pro's on this site can get me started...
    Would like to get some suggestions on which PIC, WiFi module and PC receiver to use to build this experiment.
    tia
    Is Wifi a real must? How about the expected range?
    I guess it depends on what you need, but ...
    I wouldn't mess with xbee-zigbee-newbee or whatever.
    Go with Something that gives you Everything, like serial over wifi. Using a COM port redirecter on the PC, it looks like a serial port, but it's wireless.
    HTTP server, Network Time access, etc. etc. etc.
    MatchPort® b/g
    http://www.lantronix.com/device-netw...matchport.html
    Mastream(now Digi) Xbee whatever Bee, are pretty straightforward to use... they also have Wi-fi
    Oct 2008
    thanks for the replies!
    regarding range, i would say not more than 100' from any given Tx to Rx {visualize warehouse}.
    i have been looking at these products ...
    WiFly 802.11b Serial Module - Roving Networks
    http://www.sparkfun.com/commerce/pro...oducts_id=8869
    XBee Pro 50mW Series 2.5 Wire Antenna
    http://www.sparkfun.com/commerce/pro...oducts_id=8876
    however, what Darrel pointed out with the COM redirector is quite interesting after taking a glance at the web page. I had looked at "TCPmaker" from melabs but already having a web server embedded cuts out a lot of work. the redirector takes care of getting transmitted date into, say an app like Excel or mysql.
    going to read some more from the Lantronix website.
    many thanks!!
    Bill
    Great, sounds like you're interested. So I should also say that there's NO programming to do on the PIC side.
    If you can HSEROUT to a PC with a cable, then the same program will work with the MatchPort.
    After installing the software on the PC, you just pull-up a web page with a browser to set the baud rate for the PIC and a few other options, then the device will automatically show up in the list of COM ports, in any PC program.
    Couldn't be easier.
    Unless they gave them out for free.
    Or maybe if it came with a wireless router ... which you'll need (but probably already have).
    Mar 2009
    Colorado
    Default Re: PIC && WiFi suggestions
    MatchPort® b/g
    Darrel, I am in need of a WiFi module in an embedded microcontroller application I am working on. MatchPoint b/g looks like a good match. However, I don't know what is meant by a "COM port redirecter on the PC". Can you explain?
    My application must work as follows so would appreciate your opinion as to whether Match b/g will do all this with a 16F883:
    1) 16883 and ultrasonic ranger (which gets its power from I/O pin of 16883) are awakened from sleep every 0.5 secs and ultrasonic ranger is powered up and pulsed for a range measurement (about 80msec). Ranger is checking to see if the range has changed from the previous cycle transmission. Vdd is also being internally checked in 16F883 for low battery. If either condition exists, an interrupt will be sent to the MatchPoint to wake it from sleep mode and then send date/time stamped report (from DS1307 or DS1337 RTC) containing range change and battery status via serial interface (RS232, EUSART, or what?) to MatchPort so it will transmit report via WiFi network to PC.
    2) When PC receives date/time stamped report it will check the RTC date/time against the network/PC time. If not synchronized PC tells MatchPoint to send message to 16F883 to re-synch the RTC chip (DS1337 or DS1307) time to network/PC time which is included in message. If synchronized, PC sends ACK report to MatchPoint to advise 16F883 time is still synched.
    3) 16F883, ultrasonic ranger, and MatchPoint go back to sleep mode until next 0.5 sec cycle.
    4) Repeat 1) thru 3).
    I plan on using the AT modem message mode to send serial data messages to/from MatchPort unless you suggest a different messaging technique??? I also don't know whether the EUSART of the 16F883 can be used as the RS232 interface with the MatchPort????
    I checked with Lantronix today to see if there was any way to command the MatchPort out of sleep mode by the PC on the network side. I was in hopes to do this to command the MatchPort and 16F883 out of sleep mode when the PC had data for the embedded microcontroller. Answer was no, hence my approach above to keep MatchPort awake until either a synch report, message report or ACK are received back to the 16F883.
    From what I see in MatchPort data sheet, 16F883 will not have to mess with WiFi settings or the serial settings which are already programmed into the MatchPort firmware...true??? Lantronix also told me that the PC side can't change any of these settings either since the MatchPort operates basically as a gateway....true???
    Would really appreciate your advice on achievability of above with MatchPort or if not what other WiFi device you would suggest.
    Last edited by jellis00; - 27th May 2011 at 06:21. Reason: MCU is 16F883 not 16F873
    Dec 2005
    That sounds like a lot of current for a battery operated device. How much does the MatchPort draw?
    It looks like all WiFi modules will draw in the 250mA area when transmitting.
    You might look at the ConnectOne Mini Socket iWiFi. You send it AT commands - there's an example (wired or WiFi will be nearly identical) in the new Ethernet section here. I suspect but do not know for certain that there's an AT command to wake it from deep sleep mode.
    Mar 2009
    Colorado
    Lantronix told me today that the MatchPort b/g without AES uses 740 mW when active and 250 mW when inactive and it draws 350 mAmps when data is transferred. I'm not sure whether there is a separate sleep mode in adition to inactive or not?? If not, I may have to use a NO relay under MCU control to turn power to the MatchPort on only when data needs to be sent via WiFi. Plan on using 250 mAH NiMH rechargeable battery as power source for application. The data transmit duration will be so short (maybe 0.2 secs) that the mAH load will be very small, so 250 MAH battery ought to last awhile.
    Mar 2009
    Colorado
    Thanks so much, Dave, for this info. I checked out the MiniSocket from ConnectOne and have a couple of questions:
    1) I couldn't find the "new Ethernet Section" and would like to read the example you mention that is located there. Can you be more specific as to how to find the "Ethernet Section" url location on their MiniSocket web page?
    2) You mention in another post that the MiniSocket only consumes 8 uA in sleep mode, yet the data sheet I see says it consumes 8 mA in power save mode and 40 uA in deep sleep mode. Can you please clarify where your "8 uA" comes from?
    3) I checked the AT+i Progammers Guide and I couldn't find an AT+i command to awaken the MiniSocket from PC side. I sent a question on this via email to ConnectOne and will let you know answer when I receive it.
    4) Do you have an PicBasic Pro code that you have developed for use with the MiniSocket for the PIC MCU serial interface (RS232, RS485 or UART??) that you could share with me?
    Mar 2009
    Colorado
    MatchPort® b/g
    Darrel,
    After reviewing its data sheet and your posts, I have decided to give it a go with a MatchPort b/g for our application.
    Do you have any kind of a reference design that uses one of the PIC chips with the MatchPort b/g that you could share with me? What I am looking for are:
    1) a schmatic;
    2) an example PCB interface/layouot between the PIC and the MatchPort;
    3) and some applicable PICBASIC PRO code that will setup the MatchPort and the serial interface, and also send/receive serial data/messages to/from the MatchPort using AT messages. Any help on this would be greatly appreciated.
    John Ellis
    Dec 2005
    Quote Originally Posted by jellis00 View Post
    What kind of range do you need? Could this doohickey work in your application? It might save you both work and money. Plus, it's really easy on a battery in sleep mode.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 03:19
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. PIC Suggestions
    By Tobias in forum Off Topic
    Last Post: - 7th January 2008, 06:04
