PIC16F685 RA4/RA5 pins
Results 1 to 17 of 17
    May 2007
    Suffolk, UK
    Hi Bruce
    My programme is exactly the same as yours (I removed the 1 from OSCCON bit 0). It is just the same as before. I have a 1 Mhz square wave on pin 4 and a sawtooth waveform on pin 5. I have removed everything else in the programme now apart from a LED flashing on RA1. If I try to do that on RA4/RA5 - zilch. The relevant config line was commented out in the PBP pic inc file but I had also tried programming both ways with no luck.
    Copy/paste your whole code and inc file so we can see everything.
    May 2007
    Suffolk, UK
    Hi mackrackit
    Here it is.
    To be clear I have removed the PIC from it's PCB and stuck it on a breadboard and just programmed it with these 10 lines of code. I have programmed it both with MPASM and PM with line in inc file restored.
    None of the pins are connected apart from LED on PORTA.0 which flashes. Do that on RA4 or RA% and nothing. I get a nice square wave at 1Mhz on RA4 and a sawtooth on RA5. Logic tells me I am not programming an I/O on RA4/RA5 but can't see why. Maybe there is something obvious that I keep overlooking - just too tired or too stupid. Hope you find it!!
    Code cut & pasted
    @__CONFIG _INTOSCIO & _WDT_ON & _MCLRE_OFF & _CP_OFF
    ANSEL = $00
    CMCON0 = 7
    OSCCON = $60
    TRISA  = $00
    TRISC  = $00
    Start:
    TOGGLE PORTA.0
    PAUSE 250
    goto start
    INC File
    NOLIST
        ifdef PM_USED
            LIST
            include 'M16F684.INC'	; PM header
            device  pic16F684, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F684, r = dec, w = -302
            INCLUDE "P16F684.INC"	; MPASM  Header
            ;__config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
            NOLIST
            LIST
    regards
    Adrian
    Wow that is strange. I don't have a 16F684, but this works as expected on a 16F688.
    @ __CONFIG _INTOSCIO & _WDT_ON & _MCLRE_OFF & _CP_OFF
    ANSEL = $00
    OSCCON = %01100000
    CMCON0 = 7
    TRISA = 0
    TRISC = 0
        PORTA = %00010000
        PAUSE 500
        PORTA = %00100000
        PAUSE 500
        GOTO Main
    Try the attached .hex file. It's the same code - but compiled for your 684.
    If it doesn't work, try reading it back from the chip and verifying the config settings.
    Sounds to me like your programmer isn't using the config settings embedded in the .hex.
    Note: If your device programmer isn't programming the config regs, then that would explain
    what you're seeing. The default clock would be external RC with clock out on OSC2.
    The funky signal you're seeing on OSC1 is the internal clock drive assuming an RC oscillator
    circuit is on OSC1.
    The 1MHz signal on OSC2 is the internal oscillator output. It defaults to internal osc since
    your external RC oscillator circuit isn't there. Controller thinks it has failed, defaults to
    internal 4MHz, and still outputs clock/4 on OSC2.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2007
    Suffolk, UK
    Thanks Bruce
    I'll try that tomorrow morning. Just jumping into a bath for a night on the town..!! Well not quite on the town.... at my age its more sedate but I'll have a go tomorrow and let you know. Thanks to you all
    Adrian
    May 2007
    Suffolk, UK
    Default Problem Solved!
    Hi Bruce
    Problem solved!
    Your download produced the same symptoms as my programme, but when I read it back it certainly didn't show INTOSCIO - from memory it might have been INTRC also MCLR was ON. Obviously not picking up the correct config settings as you suspected.
    I had a lucky flash of inspiration and in Microcode went to Options||More Options and pressed Set Options to Defaults.
    Immediately all came good and the PIC programmed perfectly.
    So thank you (and thanks to the others) for your help and I can get back to my PCB testing.
    I have no idea why my Microcode would not be locked solid onto its defaults. Maybe I hit something by mistake. Also would you know what parameter stopped this from programming correctly?
    Useful to remember to check in future and would save 24 hours of hair tearing......
    Adrian
    I think you may be confusing MicroCode Studio editor with your programmers software.
    I'm sure you selected something like meProg software Options, More Options, then
    Set Options to Defaults...
    , which reset programmer options. It most likely was not
    loading & using config settings embedded in your .HEX file.
    If you comment out all config options in your code, compile, then program, you'll see that
    all config options are at the default unprogrammed settings. This leaves /MCLR ON, sets
    the oscillator to external RC with clock out on OSC2, and produces exactly the same
    scenario you were seeing.
    I duplicated it exactly by doing the same thing here. Somewhere along the line you had
    changed your programmer settings to not use config settings in your .HEX file - or not
    program them.
    Check the attached graphic. I commented out the config statement in the example above,
    compiled, and launched the programmer. Check the config settings.
    The PIC is still going to run because there is no external RC clock, it assumes the external
    osc has failed, and switches over to the default internal 4MHz osc, and keeps going.
    But now you have Fosc/4 out on OSC2, and a ping signal on OSC1, which is the internal
    driver ping to tickle the external RC osc, which you don't have...;o}
    Check the diagram in the datasheet under RC OSCILLATOR MODE for a drawing of what's
    going on with these two pins when this osc mode is selected.
    -Bruce
    tech at rentron.com
    May 2007
    Suffolk, UK
    Yes thanks Bruce. Slip of the tongue between Editor & Programmer. It was the Programmer I set back to default options. I guess I must have jiggered one of the default settings which as you say stopped it loading and using the embedded settings.
    Thanks for explanation of clock settings on the 16F684. I have looked up the datasheet and see exactly what you mean.
    It's a long and slippery road but a great learning curve..........
    Adrian
  1. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 18:25
  2. PIC - 8 Pins - 6 Output Pins ?
    By DanPBP in forum Off Topic
    Last Post: - 22nd October 2007, 01:23
  3. Why does this program switch pins?
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 24th August 2006, 05:24
  4. I2C Effects on other PortA pins
    By kenmac in forum General
    Last Post: - 11th July 2005, 06:36
  5. PIC PORT 'special' pins
    By barkerben in forum General
    Last Post: - 18th January 2005, 22:40
