GOTO absolut address - is that possible?
Results 1 to 14 of 14
    Hi, joe
    YES ... looks right, but compiles and runs fine.
    After all, It's a PBP program ... intelligent compiler ? lol : might be.
    In fact, MPLAB accept both " ; " and " ' " ... as MPLAB Editor is set to "Basic" mode. Why not use what computers offer for ease of work ( Humour ...)
    Changing " ' " to " ; " do not change anything ...
    You're quite right : Manual says " line is sent verbatim" ... but, obviously, comments are not sent !!!
    Ask questions and learn, Right? <br>PBP & Assembler, like mixing 10 oz alcohol and 10 oz water, you do not get 20 oz of liquid.
    I read books AND this forum, sometimes experience and books do not agree. Anyway I try to help and am not embarrassed to learn from the masters.
    Wink
    Here is the Melabs answer :
    Below is the response that I received from MicroEngineering Labs regarding your issue:
    I've found that the problem only occurs when the assembly-language jump to our INIT routine is included:
    @ GOTO INIT
    I'm guessing that since the INIT label isn't a label in the program source code (it is an internal label PBP creates), it is not something that can be resolved for source-level debugging.
    User code should not jump to our INIT routine. If he wants to restart his program, he should declare a label in the source and use it instead.
    Charles Leo
    microEngineering Labs, Inc.
    ... now just have to find WHERE to place this "dummy" label ...
    ring you asap.
    Wink Happy End
    Ok, it's solved
    'Defines
    'Config
    'Program Configuration Register 1
    @		__CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_ON & _XT_OSC
    'Program Configuration Register 2
    @		__CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    Restart:
    INTCON 		= %01000000			' RB0 interrupt
    OPTION_REG  = %11000111			' TMR0 pour sous régime PS = 256 ( Rpm = 460 )
    T1CON		= %01010000			' %01000000
    CCP1CON		= %00000101
    PIE1		= %00000100
    CMCON 		= 7
    CVRCON 		= 0
    ANSEL		= 0
    ADCON0 		= 0
    ' If Program counter lost
    @ ORG 4094			' Goto the very last lines ( µP is a 16F88 )
    @ CLRF PCLATH			' right page for 12/16F( lol )
    @ GOTO _Restart 		             ' Go on again !!! ...
    @ END
    Look at the "Restart" Label ... it must be placed before the very first PBP command : here, an " INTCON = " statement.
    The ASM " Init " ( no underscore !!! ) label is automatically placed here by PBP in the .asm generated.
    This way, all the registers are re-set to the convenient values ...
  1. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  4. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
