An algorithm for controlling temperature and humidity of greenhouse and aviculture
Results 1 to 11 of 11
Threaded View
  1. #4
    May 2008
    Italy
    Amindzo, add the code necessary and it should work.
    Rdegree     var byte        ' sensor reading variable
    Sdegree     var Byte        ' Temperature setpoint variable
    RHumidity   var byte        ' Sensor Humidity variable
    SHumidity   var byte        ' Humidity setpoint variable
    TempDev     var Portx.x     ' Pin to  control the heating system
    HumDev      var Portx.y     ' pin to control water spry motor
    'make a loop delay for the time required at the end call CheckAmbient
    'Here you need also the routine for setting your setpoints
    CheckAmbient:
    if Rdegree > Sdegree then
    TempDev=Low
    TempDev=high
    Endif
    if RHumidity > SHumidity then
    HumDev=Low
    HumDev=high
    Endif
    Al.
