programming jumping game
Results 1 to 4 of 4
    bokken's Avatar
    bokken Guest
    Default programming jumping game
    Hello all:
    I am new to pic basic pro and to programming for the pic in general. I am working on a jumping game similar to that game at Cracker Barrell restaurant.
    I have a matrix of 5 X 5 "game pieces on a board and the game starts with pieces in all positions except the center, the object is to jump pieces to remove them from the board and end up with just one piece left.
    Does anyone out there have any ideas on how to organize and track the pieces using arrays or variables? Any similar work that has been done in PicBasic Pro?
    thanks for any help.
    David
    Feb 2012
    Meico,D.F.
    Default Re: programming jumping game
    '* Name : JuegoBloques.BAS *
    '* Author : Leonardo Castillo *
    '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 31/03/2011 *
    '* Version : 1.0 *
    '* Notes :Programa final, funciona correctamente *
    '* :lcd Nokia 1100 con driver PCF 8814 65x96 pixeles. *
    'Cuadros de figuras
    ; FigParada1 FigParada2 FigDer1 FigDer2
    ; 0 0 0 0 0
    ; 0 0 0 0 0 0 0 0 0 0 0 0 0
    ; 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    ; 0 0 0 0 0 0 0 0
    ; 0 0 0 0 0 0 0 0
    ; 0 0 0 0 0 0
    ;$18,$2F,$78,$2F,$18-$30,$2F,$78,$2F,$10-$09,$12,$7C,$28,$6E-$10,$29,$7E,$2A,$14
    ; FigIz1 FigIz2 FigAr_Ab1 FigAr_Ab2
    ; 0 0 0 0 0
    ; 0 0 0 0 0 0 0 0
    ; 0 0 0 0 0 0 0 0
    ; 0 0 0 0
    ;$6E,$28,$7C,$12,$09-$14,$2A,$7E,$29,$10-$18,$2E,$78,$2F,$10-$10,$2F,$78,$2E,$18
    ; Choque1 Choque2 Bloque EspacioBlanco
    ; 0 0 0 0 O O O O O |¬¬¬¬¬¬¬¬¬¬|
    ; 0 0 0 O O O O O O | |
    ; 0 0 O O O | |
    ; 0 0 0 0 0 0 O O O O O | |
    ; 0 0 0 0 O O O | |
    ; 0 0 0 0 O O O | |
    ; 0 0 0 0 O O O O O |__________|
    ;$13,$24,$68,$2B,$4C-$4C,$2B,$68,$24,$13-$7F,$49,$7F,$49,$7F-$00,$00,$00,$00,$00
    ' _CAMPO DE JUEGO__
    'c[0]=%1100011000001101=$C60D |00 00 | 00 0|
    'c[1]=%1100000110001100=$C18C |00 0|0 00 |
    'c[2]=%0000110011000000=$0CC0 | 00 |00 |
    'c[3]=%0001110010001100=$1C8C |___000__|0___00__|
    'c[4]=%1000110001100100=$8C64 |0 00 | 00 0 |
    'c[5]=%0001110011100110=$1CE6 | 000 |000 00 |
    'c[6]=%1001111001100011=$9E63 |0 0000 | 00 00|
    'c[7]=%0000110000000111=$0C07 |____00__|_____000|
    INCLUDE "modedefs.bas"
    asm
    __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_OFF & _WDT_ON & _INTRC_IO
    __CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
    endasm
    define OSC 8
    C var word[8]
    a var byte[2]
    b var byte[2]
    n var byte
    v var word
    x var byte
    y var byte
    xc var byte
    yc var byte
    xf var byte[2]
    yf var byte[2]
    PosX var byte
    PosY var byte
    LcdReg var byte
    m1 var byte[2]
    m2 var byte
    i var byte
    mascara var byte
    Lcd_sda var Portb.1 'DATO AL LCD
    Lcd_Clk var Portb.2 'CLOCK DEL LCD
    Lcd_rst var Portb.0 'RESET DEL LCD
    Abajo var Mascara.4
    Arriba var mascara.5
    Izquierda var mascara.6
    Derecha var mascara.7
    'almacena figs en eeprom
    FigBloque data $7F,$49,$7F,$49,$7F
    FigParada1 data $18,$2F,$78,$2F,$18
    FigParada2 data $30,$2F,$78,$2F,$10
    FigDer1 data $09,$12,$7C,$28,$6E
    FigDer2 data $10,$29,$7E,$2A,$14
    FigIz1 data $6E,$28,$7C,$12,$09
    FigIz2 data $14,$2A,$7E,$29,$10
    FigAr_Ab1 data $18,$2E,$78,$2F,$10
    FigAr_Ab2 data $10,$2F,$78,$2E,$18
    FigChoque1 data $13,$24,$68,$2B,$4C
    FigChoque2 data $4C,$2B,$68,$24,$13
    FigEspacioBlanco data $00,$00,$00,$00,$00
    CampoJuego data word $C60D,word $C18C,word $0CC0,word $1C8C,_
    word $8C64,word $1CE6,word $9E63,word $0C07
    goto Inicio
    'dibuja campo de juego
    DibujaCampo:
    y=0
    for yc=b[0]*4 to b[0]*4+3
    x=0
    for xc=a[0]*8 to a[0]*8+7
    gosub ObtieneImagen
    if v=1 then
    m2=FigBloque
    m2=FigEspacioBlanco
    gosub EnviaImagen
    x=x+5
    next xc
    y=y+1
    next yc
    EnviaImagen:
    Posx=x
    posy=y
    EnviaFig:
    gosub Lcd_GotoXY
    for i=0 to 4
    read m2+i,LcdReg
    gosub Lcd_SentDato
    next i
    ObtieneImagen:
    v=c[yc]>>(15-xc) & $01
    Campo:
    for i=0 to 7
    read CampoJuego+2*i,word C[i]
    next i
    ;LCD RUTINAS
    Lcd_Init:
    Low Lcd_RST
    pause 10 ' Reset minimo de 5mS recomendado
    High Lcd_RST
    'inicia escritura en modo comando LCD Nokia 1100 con Driver PCF8814
    LcdReg=$20:Gosub Lcd_SentControl' escribe Vop
    LcdReg=$90:Gosub Lcd_SentControl
    LcdReg=$aa:gosub Lcd_SentControl' modo de direcccionamiento de escritura horizontal (aa=0)-vertical(ab=1)
    LcdReg=$a4:GOSUB Lcd_SentControl' DAL=0
    LcdReg=$a6:GOSUB Lcd_SentControl' E=0 // normal display (non inverted)
    LcdReg=$af:GOSUB Lcd_SentControl' DON=1
    lcdreg=$a9:gosub Lcd_Sentcontrol' DOR (ordenamiento de datos MSB-LSB/DOR=1($a9);LSB-MSB/DOR=0 ($a8))
    LcdReg=$d2:gosub Lcd_SentControl' parcial display 1:48
    LcdReg=$2F:Gosub Lcd_SentControl' Power control set(charge pump on/off)
    LcdReg=$40:Gosub Lcd_SentControl' set start row address = 5
    LcdReg=$b0:Gosub Lcd_SentControl' set Y-address = 0
    LcdReg=$10:Gosub Lcd_SentControl' set X-address, upper 3 bits
    LcdReg=$00:Gosub Lcd_SentControl' set X-address, lower 4 bits
    LcdReg=$C0:Gosub Lcd_SentControl' mirror Y axis (about X axis)
    LcdReg=$ac:Gosub Lcd_SentControl' set initial row (R0) of the display
    LcdReg=$01:Gosub Lcd_SentControl' inicia en la linea 8 (se incrementa de 8 en 8 por cada bit del registro)
    GOSUB Lcd_clear
    Lcd_Home:
    PosX=0:PosY=0:Gosub Lcd_GotoXY
    Lcd_Clear:
    Gosub Lcd_Home
    For i=1 to 195
    Lcdreg=0:Gosub Lcd_SentDato
    Next i
    Lcd_GotoXY:
    LcdReg=%10110000 | PosY :Gosub Lcd_SentControl ' Y
    LcdReg=%00001111 & PosX :Gosub Lcd_SentControl ' X parte baja
    LcdReg=%00010000 | ($07&(posx>>4)) :gosub Lcd_SentControl ' X parte alta
    Lcd_SentControl:
    lcd_sda=0 ' envia control poniendo D/C a 0
    Lcd_SentDato: ' envia dato con D/C a 1
    lcd_clk=1
    lcd_clk=0
    n=0
    repeat
    lcd_sda = lcdreg.7
    LcdReg = LcdReg << 1
    lcd_ClK = 1
    lcd_ClK = 0
    n=n+1
    until n>7
    lcd_sda=1 ' pone D/C a 1
    Inicio:
    OSCCON= %11111110
    CMCON = 7
    ANSEL = 0
    TRISA = %00000000
    TRISB = %11110000
    OPTION_REG.7=0 'habilita pull-up
    gosub Campo
    gosub Lcd_Init
    gosub Lcd_Clear
    a[0]=0
    b[0]=0
    gosub DibujaCampo 'dibuja el primer cuadrante del campo
    xf[0]=15
    yf[0]=1
    xf[1]=15
    yf[1]=1
    IniciaJuego:
    'posiciona figura
    Mascara=PortB
    if arriba=0 then
    yf[1]=yf[0]-1
    m1[0]=FigAr_Ab1
    m1[1]=FigAr_Ab2
    elseif abajo=0 then
    yf[1]=yf[0]+1
    m1[0]=FigAr_Ab1
    m1[1]=FigAr_Ab2
    elseif izquierda=0 then
    xf[1]=xf[0]-5
    m1[0]=FigIz1
    m1[1]=FigIz2
    elseif derecha=0 then
    xf[1]=xf[0]+5
    m1[0]=FigDer1
    m1[1]=FigDer2
    m1[0]=FigParada1
    m1[1]=FigParada2
    'compara choque
    xc = xf[1]/5 'se divide entre 5 para obtener multiplos de 5 y poder
    yc = yf[1] 'obtener la posicion relativa con respecto al campo.
    gosub ObtieneImagen
    if (v=1|xf[1]>75|yf[1]>7) then 'hay choque y no modifica coordenadas
    m1[0]=FigChoque1 'xf[1]max 0 min 75|yf[1]max 0 min 7, limita un cuadro
    m1[1]=FigChoque2
    xf[1]=xf[0]
    yf[1]=yf[0]
    'actualiza campo dependiendo de la posicion del jugador
    if xf[1]<=35&yf[1]<=3 then a[0]=0:b[0]=0
    if xf[1]>35&yf[1]<=3 then a[0]=1:b[0]=0
    if xf[1]<=35&yf[1]>3 then a[0]=0:b[0]=1
    if xf[1]>35&yf[1]>3 then a[0]=1:b[0]=1
    if a[0]<>a[1]|b[0]<>b[1] then
    gosub Lcd_Clear
    gosub DibujaCampo
    a[1]=a[0]
    b[1]=b[0]
    'actualiza figura en el campo
    x=xf[0]-40*a[0]
    y=yf[0]-4*b[0]
    m2=m1[0]
    gosub EnviaImagen
    pause 400
    m2=FigEspacioBlanco
    gosub EnviaImagen
    x=xf[1]-40*a[0]
    y=yf[1]-4*b[0]
    m2=m1[1]
    gosub EnviaImagen
    pause 400
    xf[0]=xf[1] 'no hay choque y actualiza las coordenadas
    yf[0]=yf[1]
    goto iniciajuego
    Feb 2012
    Meico,D.F.
    this are a figs of a program Juego Bloques
Size:  136.5 KBName:  cont figuras.JPG
    Feb 2012
    Meico,D.F.
    '* Name : AUTOS2 .BAS *
    '* Date : 17/04/2011 *
    '* Version : 4.0 *
    '* Notes :tiene algoritmo para generar la pista en base a un *
    '* :generador de numeros al asar que sirven para elegir*
    '* :la forma de el camino de la pista. Ademas de poder *
    '* :controlar la direccion y la velocidad del vehiculo *
    '* :se ha implementado la deteccion de colicion de el *
    '* :carro con la pista *
    '* :se emplea almacenamiento de tramos de pista en me- *
    '* :moria *
    '* :Nota2ara reducir el parpadeo de las imagenes se *
    '* :movio la instruccion de borrado de la pantalla al *
    '* :inicio de la rutina de inicializacion de posicion *
    '* :y ya no interviene dentro de la rutina o ciclo de *
    '* :juego.
    'lcd Nokia 1100 con driver PCF 8814 65x96 pixeles.
    ' 0 0 <CARRO DE JUEGO 0 0 0 0
    ' 0 0 0 0 0 0
    ' 0 0 0 0 0 0 0 0 0 0
    ' 0 0 0 0 CAMPO DE JUEGO>
    ' 0 0 0 0 0 0 0 0
    ' 0 0 0 0 0 0 0 0 0 0 $E1
    ' 0 0 0 0
    ' 0 0 0 0 $C3
    ' $66,$FF,$3D,$CF,$CF,$3D,$FF,$66
    ' 0 0 0 0 $87
    ' 0 1 2 3 4 5 6 7
    asm
    endasm
    define OSC 8
    Longitud con 96
    MiNumero VAR WORD
    MiValor1 var byte
    MiValor2 var byte
    prado var byte
    pista var byte[longitud]
    Velocidad var byte
    Posicion var byte
    Trayecto var byte
    m var byte
    n var byte
    o var byte
    i var byte
    j var byte
    mascara var byte
    x var byte
    y var byte
    xc var byte
    yc var byte
    p var byte
    LcdReg var byte
    PosX var byte
    PosY var byte
    Acelerar var mascara.5
    Desacelerar var mascara.4
    AltoPantalla con 65
    AnchoPantalla con 96
    Cubo data $FF,$99,$99,$FF,$FF,$99,$99,$FF
    Blanco data $00,$00,$00,$00,$00,$00,$00,$00
    Carro data $66,$FF,$3D,$CF,$CF,$3D,$FF,$66
    goto Inicio
    ;LCD RUTINAS
    Lcd_Init:
    Low Lcd_RST
    High Lcd_RST
    LcdReg=$d0:gosub Lcd_SentControl' parcial display 1:65
    LcdReg=$00:Gosub Lcd_SentControl' inicia en la linea 8 (se incrementa de 8 en 8 por cada bit del registro)
    GOSUB Lcd_clear
    Lcd_Home:
    Lcd_Clear:
    Gosub Lcd_Home
    For i=1 to 195
    Next i
    Lcd_GotoXY:
    Lcd_SentControl:
    lcd_clk=1
    lcd_clk=0
    j=0
    repeat
    lcd_sda = lcdreg.7
    lcd_ClK = 1
    lcd_ClK = 0
    j=j+1
    until j>7
    EnviaFig:
    Posx=x*8
    posy=y
    gosub Lcd_GotoXY
    for i=0 to 7
    read p+i,LcdReg
    gosub Lcd_SentDato
    next i
    Inicio:
    OSCCON= %11111110
    CMCON = 7
    ANSEL = 0
    TRISA = %00000000
    TRISB = %11110000
    gosub Lcd_Init
    'rutina random
    'Programa para generar un numero pseudo-random
    'Modificado para generar numeros entre 1 y 3 (para el dado)
    pista[0]=%10000001
    pista[1]=%11000011
    pista[2]=%11000011
    pista[2]=%11000011
    for n=4 to longitud-1 step 4
    Dado1:
    For I = 1 to MiNumero
    Random MiNumero
    next I
    mivalor1 = MiNumero // 10
    if (mivalor1 = 0) or (mivalor1 > 3) or (mivalor1=trayecto) then goto Dado1
    trayecto=mivalor1
    Dado2:
    Random MiNumero
    next I
    Mivalor2 = MiNumero // 10
    if (Mivalor2 = 0) or (Mivalor2 > 5) then goto Dado2
    AlmacenaPista:
    if Mivalor2=3 then
    Prado=%00011000
    elseif mivalor2=5 then
    Prado=%00100100
    prado=%00000000
    if mivalor1=1 then
    pista[n]=%11110000<<1|%00000001
    pista[n+1]=((pista[n]|Prado>>3)<<1)|%00000001
    pista[n+2]=(pista[n+1]<<1)|%00000001
    pista[n+3]=%10000111
    elseif mivalor1=2 then
    pista[n]=%10000001
    pista[n+1]=%10000001 | prado
    pista[n+2]=%10000001 | prado
    pista[n+3]=%10000001
    elseif mivalor1=3 then
    pista[n]=%10000111>>1|%10000000
    pista[n+1]=((pista[n]|Prado<<3)>>1)|%10000000
    pista[n+2]=(pista[n+1]>>1)|%10000000
    pista[n+3]=%11100001
    next n
    IniciaJuego:
    gosub Lcd_Clear
    velocidad=1
    xc=3 'Inicializa coordenadas
    yc=7
    m=0
    PintaPista:
    for n=m to 7+m
    y=7+m-n
    for o=0 to 7
    p=pista[n]<<o
    if p.7=1 then
    p=cubo
    p=blanco
    x=o
    gosub Enviafig
    next o
    next n
    m=m+1
    if m=longitud-1 then m=0
    Boton:
    mascara=PORTB
    if izquierda=0 then xc=(xc-1)
    if derecha=0 then xc=(xc+1)
    if Acelerar=0 then Velocidad=(Velocidad+1)min 5
    if Desacelerar=0 then velocidad=(velocidad-1)max 1
    x=xc
    y=6
    p=Carro
    gosub Enviafig
    select case Velocidad
    case 1
    case 2
    pause 400
    case 3
    pause 300
    case 4
    pause 200
    case 5
    pause 150
    end select
    Colision:
    posicion=%10000000
    posicion=posicion>>xc
    if (pista[m] & posicion)<>0 then Choque 'Ocurre un choque y reinicia carrera
    goto PintaPista 'No hay choque y sigue
    Choque:
    xc=4
    for m=0 to 3
    gosub Lcd_Clear
    x=xc+m
    y=6-m
    p=Carro
    gosub Enviafig
    pause 300
    next m
    for m=0 to 3
    gosub Lcd_Clear
    x=xc-(m+1)
    y=3-m
    p=Carro
    gosub Enviafig
    pause 300
    next m
    gosub IniciaJuego
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  3. Who can help me checking my Programming
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 15:08
  4. Programming Pins of PICs?
    Last Post: - 15th August 2007, 18:59
  5. 16F628 & In-Circuit Programming?
    By Len in forum mel PIC BASIC Pro
    Last Post: - 19th March 2004, 13:02
