Pic18f452 with 20x4 LCD Help
Results 1 to 5 of 5
    Oct 2008
    Default Pic18f452 with 20x4 LCD Help
    Hi I am trying to initialize a CFA2004ATMIJP 20x4 LCD using a Pic18f452 @ 10MHz with PicBasic Pro. After compiling and uploading the hex file the screen stays blank. I have a 10K pot on VO and have it at around 4.2V. The LCD backlight is lit and I have used this code for an 8x2 Optrex LCD with no problems. The only modifications to the code for this LCD are setting the amount of lines to 4 lines instead of 2, and using different DDRAM Addresses such as 0x00, 0x40, 0x14, 0x54 for the LCDOUT commands. Can anyone see where I am going wrong? Thanks!
    I have verified with my dmm that all of the connections to the lcd and the pic are good and there are no shorts.
    0.1uF cap acrosss (Vss and Vdd)
    Vss = Gnd
    Vdd = 4.96V
    Vo = 4.2V
    RS = PORTE.0
    R/W = Gnd
    E = PORTE.1
    DB4 = PORTD.4
    DB5 = PORTD.5
    DB6 = PORTD.6
    DB7 = PORTD.7
    The Code
    ' PicBasic program to demonstrate operation of an LCD in 4-bit mode
    DEFINE OSC 10
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_LINES 4
    DEFINE LCD_DATAUS 50
    'Force LCD init
    FLAGS=0
    Lcdout $fe, 1 'Clear LCD screen
    'LCD set-up time
    PAUSE 2000
    MOVLF macro literal,dest
    movlw literal
    movwf dest
    Initial
    MOVLF B'10001110',ADCON1 ;Enable PORTA & PORTE digital I/O pins
    MOVLF B'11100001',TRISA ;Set I/O for PORTA
    MOVLF B'11011100',TRISB ;Set I/O for PORTB
    MOVLF B'11010000',TRISC ;Set I/0 for PORTC
    MOVLF B'00001111',TRISD ;Set I/O for PORTD
    MOVLF B'00000000',TRISE ;Set I/O for PORTE
    MOVLF B'10001000',T0CON ;Set up Timer0 for a looptime of 10 ms
    MOVLF B'00010000',PORTA ;Turn off all four LEDs drssiven from PORTA
    PORTA.4 = 0
    loop:
    LCDOUT $fe, $00, "LCD TEST" ' Display PULSVARs
    LCDOUT $fe, $40, "THIS SCREEN" ' Display PULSVARs
    LCDOUT $fe, $14, "IS 20 BY 4" ' Display PULSVARs
    LCDOUT $fe, $54, "CHARACTERS BIG" ' Display PULSVARs
    PAUSE 1000
    TOGGLE PORTA.4 ;Heartbeat LED
    Goto loop ' Do it forever
    North Norfolk UK
    Quote Originally Posted by djmachine View Post
    Hi
    cannot find any datasheet for your lcd.
    but this may help:
    PBP supports
    LCD modules with a Hitachi 44780 controller or equivalent. These LCDs
    usually have a 14- or 16-pin single- or dual-row header at one edge.
    ______
    Those are the correct addresses, but they have to be sent with a "Set DDRAM Address" command ($80).
    So $40 becomes $C0, and $14 is $94 etc..
    $80, $C0, $94, $D4
    Oct 2008
    I changed the addresses and also adjusted my Vo to 0.5V with reference to ground. But still nothing appears on the screen. Thanks for the replies.
    Forget the LCD for now, use the same code but try a Serial communication test to your PC or use HPWM and measure the frequency.. what happen???
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 00:13
  5. LCD 20X4 connect with DS1820
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 9th March 2005, 11:04
