16f88 to parallax 2x16 lcd
Results 1 to 11 of 11
    Oct 2008
    Default 16f88 to parallax 2x16 lcd
    to get a small test picbasic program to write to this LCD, what port/pin should one use on the 16f88? this LCD has on a Rx pin to receive data. i was thinking the pin would be RB5/PORTB.5.
    would that be correct?
    You can use just about any pin as long as it is not configured for analog for the serial output.
    Oct 2008
    ok, thanks!
    Oct 2008
    Default code to display a string to the parallax lcd
    should this code work to get the parallax to display a string?
    '' pic16f88
    INCLUDE "modedefs.bas"
    'DEFINE OSC 10 ' 4MHz doesn't work try others
    TRISB = %00000000 ' PORTB all outputs
    ADCON1 = %00000111 ' Disable A/D converter
    ANSEL = %00000000 ' all analog pins to digital
    PinOut VAR PORTB.5 ' Tx on RB5
    Led3On VAR PORTB.3 ' turn on LED if Tx
    BAUD con 16780 ' 2400 Baud, inverted, NoParity: conservative for testing
    PinOut = 0 ' set to a norm state
    PAUSE 100 ' a little wait time
    HIGH PinOut
    HIGH Led3On
    Pause 5000 ' LCD start up delay
    SEROUT2 PinOut, BAUD,["STR-1 012345678",13,10]
    LOW Led3On
    PAUSE 5000
    Loop:
    HIGH Led3On
    SEROUT2 PinOut, BAUD, ["STR-2 012345678",13,10]
    PAUSE 5000
    LOW Led3On
    SEROUT2 PinOut, BAUD, ["STR-3 012345678",13,10]
    goto Loop
    No, you are missing a bit here and there. Serial LCDs have their own command set. I went to this page and think these are the ones for you.
    http://www.parallax.com/Store/Access...%2cProductName
    LcdBkSpc        CON     $08             ' move cursor left
    LcdRt           CON     $09             ' move cursor right
    LcdLF           CON     $0A             ' move cursor down 1 line
    LcdCls          CON     $0C             ' clear LCD (use PAUSE 5 after)
    LcdCR           CON     $0D             ' move pos 0 of next line
    LcdBLon         CON     $11             ' backlight on
    LcdBLoff        CON     $12             ' backlight off
    LcdOff          CON     $15             ' LCD off
    LcdOn1          CON     $16             ' LCD on; cursor off, blink off
    LcdOn2          CON     $17             ' LCD on; cursor off, blink on
    LcdOn3          CON     $18             ' LCD on; cursor on, blink off
    LcdOn4          CON     $19             ' LCD on; cursor on, blink on
    LcdLine1        CON     $80             ' move to line 1, column 0
    LcdLine2        CON     $94             ' move to line 2, column 0
    LcdCC0          CON     $F8             ' define custom char 0
    LcdCC1          CON     $F9             ' define custom char 1
    LcdCC2          CON     $FA             ' define custom char 2
    LcdCC3          CON     $FB             ' define custom char 3
    LcdCC4          CON     $FC             ' define custom char 4
    LcdCC5          CON     $FD             ' define custom char 5
    LcdCC6          CON     $FE             ' define custom char 6
    LcdCC7          CON     $FF             ' define custom char 7
    This should work.
    SEROUT2 PinOut, BAUD,[LcdBLoff, LcdOn1, LcdCls]
    SEROUT2 PinOut, BAUD,["HELLO WORLD"]
    Try a test program with all of the above.
    Oct 2008
    Default follow up
    thanks for the tip. i dl'd two of the code samples from that page, mixed and matched and it still didn't work. i looked too at the melabs pages for the diff's of BS2 and PBP, just in case. but i did get it to work ,,,
    0. without setting the values for these, OSC and OSCCON, could not get anything written to the LCD. i set them for 8MHz, as 4MHz would not work. so i looked at section 4.6.1 of the datasheet and set the following...
    DEFINE OSC 8
    OSCCON= %01110100 ' internal RTC Oscillator freq select
    ' [bits 6-4 = 8MHz], [bit 2] INTOSC freq stable bit set
    1. configuration was set as HS, WDT_ON, PWRT_ON, BOD_ON, MCLR_OFF, PROTECT_OFF
    2. the baud rate set using these values, "396 or 16780" didn't work for me. but t2400 does.
    thanks for your help!!!!
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 15:59
  2. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 05:46
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. 4 line LCD with 16F88
    By anj in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 10:06
