Sleep
Results 1 to 3 of 3
Thread: Sleep
    Default Sleep
    Over the weekend I looked over the 16 key serial keypad example at Bruce's website. I was wondering how would I go about adding a SLEEP or NAP command to his code if no button is pressed I could conserve power. And also how would I make it wake up when a button is pressed? After searching the forums I've seen the @sleep, sleep for X period but have not found a good suggestion for using SLEEP. Here is Bruce's link to the keypad code:
    http://www.rentron.com/serkey16.htm
    Being the the example is using PORTB...
    http://www.picbasic.co.uk/forum/show...77&postcount=3
    I saw that post earlier, not having much if any knowledge on Assembly, I wasn't quite sure what was going on. I tried it out, added a while;wend with an led flashing when it arrived at that point and then after added @sleep @no. I believe that the NOP clears the GIE bit according to the '628 datasheet but noticed that the example on this forum showed it added twice. Anyhow I powered the '628 with a 78L05 regulator with a 9V battery without using the @SLEEP and I am drawing 12mA measuring from battery into the regulator. With the @SLEEP command I am still drawing 12mA so believing that the regulator is the cause. The Quiescent Current on the 78L05 is 3 min. 5mA max and on the LP2950CZ-5.0 it is 75uA. I have ordered a LP2950CZ-5.0 regulator. Perhaps this will cure my project's hunger for batteries.
    Thanks for your help, '73
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
  5. SLEEP Command and Interupts 16F648A
    By ghoot in forum mel PIC BASIC Pro
    Last Post: - 28th May 2004, 18:35
