How to get ASCII data in array.
Results 1 to 9 of 9
    Default How to get ASCII data in array.
    Hi to all.
    I wonder if the modifier DEC can be used with STR in data array reception like this:
    Hserin [DEC3 STR array\n]
    I know the above won't compile, but as I am getting ascii data in 3 bytes packets, is there a special syntax that might do the trick?
    Would something like this work?
    [STR NUMS\16]
    X1 = (NUMS[1]-"0")
    X2 = (NUMS[3]-"0")
    X3 = (NUMS[5]-"0")
    X4 = (NUMS[7]-"0")
    X5 = (NUMS[9]-"0")
    X6 = (NUMS[11]-"0")
    X7 = (NUMS[13]-"0")
    X8 = (NUMS[15]-"0")
    Do the 3 bytes ever represent more than 255?
    If not, this might work ...
    For LoopCount = 0 to n-1
        HSERIN [DEC3 array(LoopCount)]
    Next LoopCount
    But there's a distinct possibility of getting the wrong numbers if there's nothing between the 3 byte data packets.
    Thanks boys.
    Currently, I do a simple 28bytes communication between radio modems using DT instant interrupts to get the Serial data like this:
    Get_char:
       ser_in=0
          hserin 100,noreceived,[wait("##"),str temp_array\file]   'Get 28 characters
          if temp_array[0]=node then          'Are for this node station?
             ser_in=1	                    'if yes, then flag data and copy
    noreceived:                         'else return
    @ INT_RETURN
    If data are coming to the serial port, then if the 2 first are ## data are captured in the temp_array (28 long)
    The first byte is the node station. If data are for this node, then a flag is raised.
    My concern is that, data can be any number including the $23 which is '#' character.
    So this might lead the routine to hang if data are out of sync sometime.
    My thought was to use data in the array only in ascii form without increasing length of temp_array x 3, by converting the ascii values while receiving them.
    Why not use a TimeOut? Or can you not afford to miss any data?
    Please see the previous than yours post, that shows the timeout is there. But Darrel has explained very well why this might hang here:
    http://www.pbpgroup.com/modules/newb..._id=28&forum=8
    OOPPS, I was sleepy?
    That was interesting, I now have it bookmarked.
    Just curios, is that the same project?
    No. That was an easy (now, for me...) project. It just transmitted the number in 3 bytes form. E.g. if number was 128 then the port would transmit ASCII '1', ASCII'2' and ASCII '3' or 49, 50 and 56 as decimal values.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
