Thank you Bruce!
Yes, that was true (RB4=0)! It works as it should! I already tested it...
My PIC environment seems to work as it should also with RC5 pulled up. I assume that it does not harm, however because it is with a SMD resitor pulled up I can not (want not) remove it just to check the theory.
My next step is now to invoke the bootloader from my application, not from the boot sequence with RB4=0. In other words, when the real application is running I would like to jump from there to the bootloader, to that location where RB4 is tested and the decision has been made to continue with the bootloader.
To do this one need first to find that point in the bootloader.
MPLAB can dissamble a hex file, can it really?
Is it View/Disassembly listing? I can't see anything in that listing...
Any ideas?
Can one really use MPLAB to disassembly pic.HEX?
Maybe it would be better to start a new thread with completely new approach to this? Or then not...![]()
