Select Case range of values
Results 1 to 4 of 4
    Mar 2005
    Cocoa, Florida
    Default Select Case range of values
    A case statement that allowed a range of values would be very helpful. As it is, I can't find any syntax that works (>5 AND <20, for instance, is a dud)
    SELECT CASE var
    CASE 27 TO 53
    END SELECT
    Is there a workaround, short of building a long CASE staircase?
    Jan 2006
    Istanbul
    A <font color="#000080"><b>VAR BYTE
    SELECT CASE </b></font>A
        <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000">5 </font><font color="#000080"><b>AND IS </b></font>&lt; <font color="#FF0000">20
            </font><font color="#000080"><i>' do your stuff...
        </i><b>CASE IS </b></font>&lt; <font color="#FF0000">40 </font><font color="#000080"><b>AND NOT </b></font><font color="#FF0000">35
    </i><b>END SELECT
    </b></font>
    Quote Originally Posted by sayzer View Post
    </font>
    That's what I thought too. &nbsp; But when I tried it in a test program, it didn't work.
    It's not in the manual, even though it compiles without warnings. &nbsp; So I wasn't sure if it was valid.
    I asked meLabs, and they said ...
    "SELECT CASE isn't capable of logic in the cases. Never has been."
    Quote Originally Posted by kenif
    I quess you'll need to use IF statements instead of SELECT CASE.
    IF (A >= 5) AND (A <= 20) THEN
        ; something
        IF (A > 20) AND (A <= 40) THEN
             ; something else
    Wink
    A VAR BYTE
    SELECT CASE A
        CASE IS > 5 AND IS < 20
            ' do your stuff...
        CASE IS < 40 AND NOT 35
                ' do your stuff...
    END SELECT
    could be Written
    SELECT CASE A
        CASE IS <= 5
        CASE IS < 20
            LCDOUT $FE,2, " < 20 " , DEC3 A
        CASE 35
        CASE IS < 40
            LCDOUT $FE,2, " < 40 " , DEC3 A
       CASE ELSE
    END SELECT
    CASE A left "blank" works fine...
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
