How to calculate a Triac's power dissipation
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default How to calculate a Triac's power dissipation
    Hello,
    Is there any "rule of thumb" or simple way to calculate a triac's power dissipation?
    I'm trying to build-up a simple micro-controlled 230VAC light switch for incandescent bulbs (purely ohmic) and I would prefer to understand how to correctly choose a triac instead of just taking the ones proposed in the examples one can find in the internet.
    As far as I could find information up to now, it looks to be necessary to use the graphs provided in some datasheets to determine each triac's power dissipation.
    But one can't read every datasheet to find out the adequate triac to use...
    This AN from PHILIPS http://www.nxp.com/acrobat_download/.../AN10384_1.pdf might be very explicit for electronicians; for me, it is too complicated.
    Thanks for any info
    Roger
    Wink
    Hi, Roger
    your Triac has a "saturation voltage" ... Current ( RMS ! ) flows through ...
    ... P = ?? * ??
    Roger ... you got excuses, cause, for once you've tried to calculate before burning your components ... lol
    Amitiés from France
    Default ...just getting older :-)
    Hello Alain,
    You're right, I don't have enough triacs in stock to allow many tests
    Okay for the Irms but still knowing this, how must I understand the datasheet (this one, for example https://www.distrelec.com/distrelec/...-T8_Data-E.pdf)?
    Witch caracteristic is the Saturation Voltage then?
    I don't know witch value(s) I need to take care of to calculate the triac... sorry, I'm only a an electrician...
    Roger
    Default basics...
    I found what I was looking for here http://www.signindustry.com/electric...xplainted.php3
    Roger
    Default triacs
    i think most all triacs will produce about 1 watt per amp...
    amgen
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  4. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  5. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
