12F683 and DT Instant Interrupts
Results 1 to 27 of 27
    GOTO MAIN 'is this dangerous ?
    Suicidal!
    You will only get one interrupt that way, untill power is cycled or the GIE bit is set manually.
    If you need to trigger processes in the main loop, you can set a Flag in the handler. Once it returns from the handler, the main loop can execute the required task where it can be interrupted again.
    On 12F's and 16F's, you should NEVER gosub from the handler. There just aren't enough stack levels.
    Nov 2008
    "Suicidal" I like it Darrel :-)
    That word doesn't get used in code discussion much I'm sure...
    OK, I just hit 'undo' on my code several times to stop myself needing to go slash my wrists ;-)
    Flag. OK, if I understand correct I should set a flag variable in the int handler, then put my main code into a tight loop checking for it, then jump to my PPM output code when true, then back to the tight loop after clearing the flag...
    There are a heap of ways to make a tight loop (If-then, While-wend, repeat-until). What would be the tightest (fastest) ? ASM ?
    Martin
    Quote Originally Posted by mr.sneezy View Post
    Anything that requires precise timing should be done in the handler, preferably in an ASM handler.
    When it returns to the Main loop with a Flag set, the process it triggers should be able to do it, "whenever it gets around to it". There may be several things going on, and there's no guarantee when it will be processed.
    If you're reading servo pulses, then the entire process of measuring the pulse should be done with the interrupts, and I don't mean sitting in a PULSIN statement in the handler. On the rising edge, start a timer. On the falling edge, stop the timer and collect the reading. Each time leaving the handler until the next condition occurs. Once you have a reading, then set a flag to let the main loop know to process the data. Now it has all the time in-between pulses to work on all those error rates, jitter etc and display them on the LCD at it's leisure.
    Nov 2008
    Thanks Darrel,
    In this part of the project (maybe the only part) I'm making the pulses, eight in a row for eight RC servo channels, of varying periods, rather than reading them. The TMR1 interrupt is just keeping the overall frame timing right.
    Looking it now I think a tight loop reading the roll-over flag of the counter then doing the pulse train code would have worked just as well. I guess I thought that a real timer interrupt would minimise jitter in the total frame length.
    Never mind, I'll carry on with the interrupt method now that I've started it.
    I'd still like to see Alains code though.... Alain ?
    Martin
    Talking You've asked for it ... do not cry, now !!!
    Hi, Martin
    Darrel will love it, for sure !!! ( Lol ...)
    'FRAMEGEN.BAS
    ' Générateur de Trame R/C Graupner/Multiplex sur 12F675
    ' 4,7,8 ou 9 Canaux - Neutre 1.5 ms
    ' Oscillateur interne 4 Mhz
    ' Trames déclenchées par interruptions TMR0 : PS = 1/128 Pl = 80
    ' Sortie sur GPIO.5
    ' Choix 4,7,8 ou 9 voies sur GPIO.3 et 4
    @    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BODEN_ON
    DEFINE OSCCAL_1K 1
    DEFINE INTHAND _Marker
    ADCON0		= 0
    ANSEL		= 0
    CMCON		= 7
    OPTION_REG	= %10000110     'Disable Pull-Ups - PSA = 128
    INTCON		= %00100000		'TMR0 interrupt
    PIE1		= 0
    PIR1 		= 0
    ' Constantes
    Mark 	CON 400
    Reload 	CON 80
    Neutral CON 1500
    GR		CON 8
    MPX		CON 9
    ' Variables
    PROGRAM		var byte
    PROGRAMOLD	var byte
    FRAME4		var bit
    FRAME7		var bit
    FRAME8		var bit
    CLEAR
    ' I/Os
    GPIO 		=%00100000	'GPIO.5 = 1 at startup
    TRISIO 		=%00011000  'set GPIO3 GPIO4 as input GPIO.5 as Output
    GOTO INIT
    Marker: ' Interruption - Génération de la trame
    TMR0 = Reload
    GPIO.5 	= 0
    PAUSEUS	Mark
    GPIO.5 	= 1				' Voie 1
    PAUSEUS 696
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 2
    PAUSEUS 796
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 3
    PAUSEUS 896
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 4
    PAUSEUS 992
    IF FRAME4 THEN Selection
    @ NOP
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 5 - 1500µS
    PAUSEUS 1096
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 6
    PAUSEUS 1196
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 7
    PAUSEUS 1290
    IF FRAME7 THEN Selection
    @ NOP
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 8
    PAUSEUS 1392
    IF FRAME8 THEN Selection
    @	NOP
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 	= 1				' Voie 9
    PAUSEUS 1496
    Selection:
    GPIO.5 = 0
    PAUSEUS Mark
    GPIO.5 = 1
    'Lecture des Jumpers
    PROGRAM = GPIO & %00011000
    IF PROGRAMOLD <> PROGRAM THEN INIT
    Start: 'Fin d'Interruption
    INTCON.2 = 0
    INTCON.7 = 1
    CYCLE: 'Boucle de fonctionnement
    WHILE 1
    WEND
    INIT: 'Lecture des Jumpers
    SELECT CASE Program
    	CASE 24
    		FRAME4 = 1 : FRAME7 = 0 : FRAME8 = 0
    	CASE 16
    		FRAME4 = 0 : FRAME7 = 1 : FRAME8 = 0
    	CASE 8
    		FRAME4 = 0 : FRAME7 = 0 : FRAME8 = 1
    	CASE ELSE
    		FRAME4 = 0 : FRAME7 = 0 : FRAME8 = 0
    END SELECT
    PROGRAMOLD = PROGRAM
    GOTO Start
    If you want to have variable pulse length... just inc or dec the PAUSEUS value before the "START" Label
    And ... if you find something strange ... it is NOT an error !!!
    ( I told you Darrel would love it ....)
    Love comes in many forms ...
    I'm still looking for the one that applies here.
    Ummm, I found something strange ...
    Wink I should had bet 50$ !!!
    Hi, Darrel,
    Really ???
    I'm so surprised ... Something missing, may be ???
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
