12F683 and DT Instant Interrupts
Results 1 to 27 of 27
    Default 12F683 and DT Instant Interrupts
    I am trying to use Darrel Taylor's great Instant Interrupts (thank you!) on a 12F part. Originally, I was using a 12F635. I changed to a 12F683 after reading posts about doing this, because I was under the impression it would work O.K. However, I still get the following message when compiling:
    ERROR:Variable wsave2 position request 288 beyond RAM_END 191.
    Do I still need to comment out some lines?
    @ device pic12f683, INTRC_OSC_NOCLKOUT, WDT_OFF, MCLR_OFF, PROTECT_OFF
    OPTION_REG = %11000000
    OSCCON = %01100001
    TRISIO = %001100
    CMCON0 = %00000111
    ANSEL = 0
    CCP1CON = 0
    RATESW VAR BYTE
    HIGH GPIO.0
    HIGH GPIO.1
    HIGH GPIO.4
    HIGH GPIO.5
    RATESW = 0
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INT_Handler INT_INT, _SWINT, PBP, yes
    INT_ENABLE INT_INT ; enable external (INT) interrupts
    if ratesw = 1 then Rate1
    if ratesw = 2 then rate2
    if ratesw = 3 then rate3
    if RATESW > 3 then RESET
    GOTO Main
    Rate1:
    while ratesw = 1
    LOW GPIO.0
    low GPIO.1
    pause 150
    high GPIO.0
    high GPIO.1
    low GPIO.4
    low GPIO.5
    PAUSE 150
    high GPIO.4
    high GPIO.5
    wend
    Rate2:
    while ratesw = 2
    LOW GPIO.0
    low GPIO.1
    high GPIO.0
    high GPIO.1
    low GPIO.4
    low GPIO.5
    PAUSE 100
    high GPIO.4
    high GPIO.5
    wend
    Rate3:
    while ratesw = 3
    LOW GPIO.0
    low GPIO.1
    pause 50
    high GPIO.0
    high GPIO.1
    low GPIO.4
    low GPIO.5
    PAUSE 50
    high GPIO.4
    high GPIO.5
    wend
    RESET:
    RATESW = 0
    GOTO Main
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    SWINT:
    while GPIO.2 = 0:wend
    if GPIO.2 = 1 then
    RATESW = RATESW + 1
    @ INT_RETURN
    Thank you
    Yes, open DT_INTS-14.bas file.. and at the top, you'll discover...
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    Thank you for the reply. Unfortunately, I have all three lines commented out and now I get "Unable to fit wsave" .
    From that error, it looks like you're still compiling for the 12F635.
    If using MicroCode Studio, make sure the device dropdown box says 12F683.
    For the 683, you'll need both wsave and wsave1.
    Or you can use the alternate wsave location $70, and comment the other 3.
    Thank you Darrel. Yes , the drop-down was incorrect. The program doesn't work, but that's because it's still Halloween!
    Nov 2008
    Default 12f683 messages too...
    I'm trying to get my head across the DT Interrupt code for a small new RC modeling project and I'm trying a test example first (the blinky LED) , compiling with MCS. I have 12f683 selected in MCS and MPASM being used.
    but I get an odd warning message from MCS thus :
    Warning[219] d:\pbp code\pbp\pbppic14.lib 336 : Invalid RAM location specified
    Warning[219] d:\pbp code\pbp\pbppic14.lib 892 : Invalid RAM location specified
    Anybody know why and if I should just disregard it ?
    I commented out the wsave lines as required (which led me here BTW)
    My code
    LED1   VAR  PORTB.1
    RBIF = GPIF
    RBIE = GPIE
    T1CON = $31                ; Prescaler = 8, TMR1ON
      PAUSE 1
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    My project is quite simple. A 22.5mS interrupt timer (TMR1 I guess) and toggle a few pins then wait for the next interrupt.
    Martin
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
