Old classic If-Then...
Results 1 to 17 of 17
    Hi Ioannis,
    That error is comming from ReEnterPBP.bas
    There's no way for it to know if the complex formula/IF statement is in the main program or the interrupt handler. And if it's in the handler, it will end up overwriting PBP's system vars.
    If you know for sure that the offending statements are NOT in the handler. You can open the ReEnterPBP.bas file and comment the error line.
            ifdef T5
    ;            ERROR "Temp variables exceeding T4"
    HTH,
    Hi Darrel,
    So if I understand this right, ERROR is a reserved word in assembler, and if IFDEF calls it then MPASM displays the error when compiling . . . YES?<br><br> Hi Steve, thanks , I will give that some thought.
    Hi Darrel,
    Yup. You got it.
    Hi. Thanks for the replies.
    Alain: I was going to use the syntax later (if thermistor then...), after I had my program working. But as Darrel explained, this would have no effect as the error was coming from the ReEnterPBP.bas.
    Darrel: Thanks for the explanation. I forgot to mention that I was using yours routine for the Interupts, sorry... But did not imagine that this could be coming from the ReEnterPBP.bas. It seemed more logical to be a problem of the Assembler or Compiler.
    Useful the tip for the error.
    Anyway, many thanks to all.
  1. Classic
    By Haggar in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 10:57
