Hi, Ioannis
Do not use " IF thermistor1 = 1" but "IF Thermistor" ... result is the same
Do not use " IF thermistor1 = 0 " but "IF NOT Thermistor" ... result is the same
Hi, Ioannis
Compile fineCode:if (pump=0) and ( thermistor1 or thermiko1 or ( onboard_an2>(pres_limit + 10))) then module_rel_out.0=0 endif if (level>stop_level) then if pump=0 then module_rel_out.0=0 endif endif
BUUUUUUT ... I do think you should make your Karnaugh Table ( Table of states ) "a bit" clearer ... might help a lot ( lol )
Thanks Alain,
For
It gives me a new test tool, never could see a use for that command before. Sometimes it's not the main point of your posting that benefits others, sometimes it's the little things that you use everyday.Code:RANDOM Level RANDOM Onboard_An2
I understand why.. the problem is to explain... enjoy the following language barrier mess
If ConditionIsTrue Then DoSomething
Dealing with Bit Var, you have ONLY 2 choices... OR the var is 1 OR the var 0, True or False.
So why messing with condition if your variable already hold it?
It's just another way to write your IF-THEN
