Old classic If-Then...
Results 1 to 17 of 17
Threaded View
  1. #7
    Wink
    Hi Ioannis
    I do not Understand you ...
    'Essai 16F84 Random
    DEFINE LCD_EBIT 1                          ' Other LCD pins are same as Manual - Holy Manual - my sweet Manual ...
    '   DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
    '   DEFINE LCD_DBIT 0
    '   DEFINE LCD_RSREG PORTB
    '   DEFINE LCD_RSBIT 4                  ' Register select pin
    '   DEFINE LCD_EREG PORTB
    '   DEFINE LCD_EBIT 5                   ' Enable pin
    '   DEFINE LCD_BITS 4                   ' 4-bit data bus
    '   DEFINE LCD_LINES 2                  ' LCD has 2 character lines
    @	__config _XT_OSC & _WDT_ON & _CP_OFF
    'Variables
    Level 	   		var Word
    High_Level 		var Word
    Onboard_an2		var Word
    PressLimit 		var Word
    Auto1			var Bit
    Thermikol 		var Bit
    Thermistor1		var Bit
    Pump			var Bit
    LevelOk			var Bit
    PressOk			var Bit
    module_rel_out	var Portb.7
    'Constantes
    'Preset
    CLEAR
    PORTA = 0
    PORTB = 0
    TRISA = 0
    TRISB = 0
    High_Level 	= 40000
    Level		= 0
    Thermikol   = 1
    Thermistor1	= 1
    Onboard_an2 = 500
    PressLimit 	= 35000
    Auto1		= 1
    Pump		= 0
    PAUSE 500
    LCDOUT $FE,1
    RANDOM Level
    RANDOM Onboard_An2
    Loop:
    RANDOM Level
    RANDOM Onboard_An2
    IF (level <= high_Level) THEN
     	PORTB.5 = 1
      	PORTB.5 = 0
    IF ( onboard_an2 <= PressLimit ) THEN
     	PORTB.6 = 1
      	PORTB.6 = 0
    Module_rel_out =  (level <= high_Level) && Thermikol && Thermistor1 && Auto1 && ( onboard_an2 <= PressLimit ) && !Pump
    LCDOUT $FE,2,# Module_Rel_Out ,"   ",DEC5 Level ," ",DEC5 Onboard_an2 ,"  "
    LCDOUT $FE,$C0,"out", DEC5 High_Level, " ", DEC5 Presslimit
    PAUSE 300
    IF Module_rel_out THEN PAUSE 500
    GOTO Loop
    As you see ... I played somewhat with my Personnal Testboard to verify everything was running fine ...
    And it runs fine !!!
    "your" line is here :
    Value Comparisons or logic levels have equal behaviour here ...
    Cheers ...
  1. Classic
    By Haggar in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 10:57
