Old classic If-Then...
Results 1 to 17 of 17
    Default Old classic If-Then...
    I got a little confussed on this nested If-Then:
    if level<=high_level then
    	if thermiko1=0 then
    		if thermistor1=0 then
    			if auto1=0 then
    				if onboard_an2<=pres_limit then
    					if pump=0 then
    						module_rel_out=1
    						module_rel_out=0
    does make module_rel_out=1 but does not makes it 0 if the conditions (one or more) are not met.
    I am missing something but cannot figure what...
    Any help appreciated.
    You need to insert the ELSE statement for each IF. For example, if the first IF is not true, the code never gets to the ELSE ...=0
    to execute this part...
    if pump=0 then
    						module_rel_out=1
    						module_rel_out=0
    ALL previous conditions have to be met.
    Simply pre-load the ELSE condition into the variable before entering the IF loop...
    module_rel_out=0
    	if thermiko1=0 then
    			if auto1=0 then
    					if pump=0 then module_rel_out=1
    Wink
    Hi, Ioannis
    Why not use an AND combination of your conditions.
    Karnaugh would LOVE your example.
    Try this little soft ... and ENJOY.
    Karnaugh Minimizer 2.0
    Copyright (c) 2002-2007 ShurikSoft.
    http://www.shuriksoft.com
    Hi all and thanks for the replies.
    Alain: I tried with AND but got an error of too many variables. Indeed was long line!
    Melanie: That was what I did just before reading your post. Yes this works but was not appealing to me as an elegant solution.
    Steve & Tobias: Yes,I see now, after the morning cup of coffee that it never reached the ELSE statement.
    Thanks again to all.
    Wink
    Hi Ioannis
    I do not Understand you ...
    'Essai 16F84 Random
    DEFINE LCD_EBIT 1                          ' Other LCD pins are same as Manual - Holy Manual - my sweet Manual ...
    '   DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
    '   DEFINE LCD_DBIT 0
    '   DEFINE LCD_RSREG PORTB
    '   DEFINE LCD_RSBIT 4                  ' Register select pin
    '   DEFINE LCD_EREG PORTB
    '   DEFINE LCD_EBIT 5                   ' Enable pin
    '   DEFINE LCD_BITS 4                   ' 4-bit data bus
    '   DEFINE LCD_LINES 2                  ' LCD has 2 character lines
    @	__config _XT_OSC & _WDT_ON & _CP_OFF
    'Variables
    Level 	   		var Word
    High_Level 		var Word
    Onboard_an2		var Word
    PressLimit 		var Word
    Auto1			var Bit
    Thermikol 		var Bit
    Thermistor1		var Bit
    Pump			var Bit
    LevelOk			var Bit
    PressOk			var Bit
    module_rel_out	var Portb.7
    'Constantes
    'Preset
    CLEAR
    PORTA = 0
    PORTB = 0
    TRISA = 0
    TRISB = 0
    High_Level 	= 40000
    Level		= 0
    Thermikol   = 1
    Thermistor1	= 1
    Onboard_an2 = 500
    PressLimit 	= 35000
    Auto1		= 1
    Pump		= 0
    PAUSE 500
    LCDOUT $FE,1
    RANDOM Level
    RANDOM Onboard_An2
    Loop:
    RANDOM Level
    RANDOM Onboard_An2
    IF (level <= high_Level) THEN
     	PORTB.5 = 1
      	PORTB.5 = 0
    IF ( onboard_an2 <= PressLimit ) THEN
     	PORTB.6 = 1
      	PORTB.6 = 0
    Module_rel_out =  (level <= high_Level) && Thermikol && Thermistor1 && Auto1 && ( onboard_an2 <= PressLimit ) && !Pump
    LCDOUT $FE,2,# Module_Rel_Out ,"   ",DEC5 Level ," ",DEC5 Onboard_an2 ,"  "
    LCDOUT $FE,$C0,"out", DEC5 High_Level, " ", DEC5 Presslimit
    PAUSE 300
    IF Module_rel_out THEN PAUSE 500
    GOTO Loop
    As you see ... I played somewhat with my Personnal Testboard to verify everything was running fine ...
    And it runs fine !!!
    "your" line is here :
    Value Comparisons or logic levels have equal behaviour here ...
    Cheers ...
    Hi Alain.
    On the following if I try to put the second if-then inside the logic expression, I get an "Temp variables exceeding T4" error in MPASM assembler.
    This compiles OK:
    if pump=0 and (thermistor1=1 or thermiko1=1 or onboard_an2>(pres_limit+10)) then
    	module_rel_out.0=0
    if level>stop_level then
    	if pump=0 then
    		module_rel_out.0=0
    This produces the above error:
    if pump=0 and (thermistor1=1 or thermiko1=1 or onboard_an2>(pres_limit+10) or level>stop_level) then
    	module_rel_out.0=0
    Wink
    Hi, Ioannis
    Do not use " IF thermistor1 = 1" but "IF Thermistor" ... result is the same
    Do not use " IF thermistor1 = 0 " but "IF NOT Thermistor" ... result is the same
    Wink
    if  (pump=0) and ( thermistor1 or thermiko1 or ( onboard_an2>(pres_limit + 10))) then
    	module_rel_out.0=0
    if (level>stop_level) then
    	if pump=0 then
    		module_rel_out.0=0
    Compile fine
    BUUUUUUT ... I do think you should make your Karnaugh Table ( Table of states ) "a bit" clearer ... might help a lot ( lol )
    Thanks Alain,
    For
    RANDOM Level
    RANDOM Onboard_An2
    It gives me a new test tool, never could see a use for that command before. Sometimes it's not the main point of your posting that benefits others, sometimes it's the little things that you use everyday.
    Hi, Ioannis
    Could you please explain a little more, so I can understand why ?
    Thank You
    I understand why.. the problem is to explain... enjoy the following language barrier mess
    If ConditionIsTrue Then DoSomething
    Dealing with Bit Var, you have ONLY 2 choices... OR the var is 1 OR the var 0, True or False.
    So why messing with condition if your variable already hold it?
    It's just another way to write your IF-THEN
    Hi Ioannis,
    That error is comming from ReEnterPBP.bas
    There's no way for it to know if the complex formula/IF statement is in the main program or the interrupt handler. And if it's in the handler, it will end up overwriting PBP's system vars.
    If you know for sure that the offending statements are NOT in the handler. You can open the ReEnterPBP.bas file and comment the error line.
            ifdef T5
    ;            ERROR "Temp variables exceeding T4"
    HTH,
    Hi Ioannis,
            ifdef T5
    HTH,
    Hi Darrel,
    So if I understand this right, ERROR is a reserved word in assembler, and if IFDEF calls it then MPASM displays the error when compiling . . . YES?<br><br> Hi Steve, thanks , I will give that some thought.
    Hi Darrel,
    Yup. You got it.
    Hi. Thanks for the replies.
    Alain: I was going to use the syntax later (if thermistor then...), after I had my program working. But as Darrel explained, this would have no effect as the error was coming from the ReEnterPBP.bas.
    Darrel: Thanks for the explanation. I forgot to mention that I was using yours routine for the Interupts, sorry... But did not imagine that this could be coming from the ReEnterPBP.bas. It seemed more logical to be a problem of the Assembler or Compiler.
    Useful the tip for the error.
    Anyway, many thanks to all.
  1. Classic
    By Haggar in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 10:57
