squelch doesn't seem the way to go
Results 1 to 14 of 14
    Thanks again for all of the suggestions, I will go back to the datasheet and and read about uart, Thanks Eng.Alamin for the sample, well I am off to see what I can accomplish with this information.
    Thanks again to all.
    By the way I am using the 16F628A processor.
    Nice, it also have the built-in voltage comparator, reducing the external hardware to a minimum.
    Although now I will focus on Uart, I been playing around this evening with my experiment after all I spent a lot of time on this and without etching a new pcb this would be sent to the scrapbox. I wanted to mention to Aratti that his sugggestion :
    Flag=0
    loop1:
    Flag=Flag+1
    If flag=>100 then goto Jumpout
    SERIN2 serialpinin,16468,100,loop1,[wait(254),a,b,c,d,e,f,g,h,i,j,k,l]
    Jumpout:
    At first it would not work for me and after all the questions I have asked on this forum one piece of advice stuck, that was when Skimask pointed out that "start thinking of PICs not as a teenager that can be told what to do ('cause that's what I see), but as a 6 year old that has to be told EXACTLY WHAT to do, WHEN to do it, HOW to do it, and to know yourself WHY he/she is doing what he/she is doing and HOW he/she is going to accomplish it". then Then light bulb lit in my head,I began to think how I could use Aratti's suggestion.
    Here is what I did:
    while flag < 1
    SERIN2 serpin,16468,[wait(254),a,b,c,d,e,]
    flag = flag + 1
    wend
    Now with the squelch wide open and the data pin toggling, Guess what??? It worked!!!!!!!!!!! keep in mind variable a-d are byte size and are all the same data and e is my check sum, the total sum of a-d, then I compare a-d if they match I multiply e * 4 and if it matches I count by 1 up to ten. If they don't match I set my counting variable1 to 0. If they match I set my counting variable2 to 1. If they match TEN times IN A ROW then my data is assumed good so I go to my next loop and turn on/off my functions, I seemed to have had some mutipath here in my metal barn so I just adjusted my counting variables to allow for errors. That kept my output on or off long enough to take some more samples. Now it works fast and seems very reliable. I've been doing flips etc. to make it act up and so far it hasn't missed anything that I know of, the outputs is on or off depending on if I was pressing the switch. Anyhow, I am waiting for the bubble to pop, LOL. As ya'll can see I don't like to give up. now that this is working, for now that is, I am off to UART. I'll be back with many more questions on that, I'm sure.
    Thanks everyone.
  1. RF Transmitter/Reciver
    By Fredrick in forum General
    Last Post: - 4th May 2008, 02:19
  2. SERIN Timeout
    By George in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 16:06
