Multiple AND's
Results 1 to 6 of 6
Thread: Multiple AND's
    Default Multiple AND's
    This seems to work:
    If (a = B) && (a = c) && (a = d) && (a = e) && (a = f) && (a = g) &&(a = g) && (a = i) && (a = j) && (a = k) && (a = l) THEN
    m = 1
    m = 0
    But is this the only way to do this?
    There are as many ways as you have imagination...
    	m=0
    	If (a = B) then
    		if (a = c) then
    			if (a = d) then
    				if (a = e) then
    					if (a = f) then
    						if (a = g) then
    							if (a = h) then
    								if (a = i) then
    									if (a = j) then
    										if (a = k) then
    											if (a = l) then m=1
    That one kinda looks pretty...
    Jan 2006
    Istanbul
    IF (a*a*a*a*a*a*a*a*a*a*a) =  (a + b+ c +d +e + f +g +h +i +j +k +l) THEN DO
    Could this work?
    _____________-
    I initially thouhgt doing the addition thing... but it wouldn't work...
    (a*11)=(b+c+d+e+f+g+h+i+j+k+l)
    looks fine untill you consider the equation would still be true if one of the values was less than a, whilst another of the values was greater than a by the same amount.
    Another way ...
    Idx   VAR BYTE
    Vars  VAR BYTE[12]
      a   VAR Vars[0]
      b   VAR Vars[1]
      c   VAR Vars[2]
      d   VAR Vars[3]
      e   VAR Vars[4]
      f   VAR Vars[5]
      g   VAR Vars[6]
      h   VAR Vars[7]
      i   VAR Vars[8]
      j   VAR Vars[9]
      k   VAR Vars[10]
      l   VAR Vars[11]
      m   VAR BYTE
    For Idx = 1 to 11
        IF a != Vars[Idx] THEN m = 0 : GOTO VarTestDone
    NEXT Idx
    m = 1
    VarTestDone:
    Wink little useful question ...
    Hi,TaznTex
    As it looks close to logics ... Could you tell what kind of variables are "a" to "l" ???
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  2. Multiple "AND"'s in select case?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st January 2010, 19:10
  3. Problems controlling multiple pics
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 29th May 2007, 08:59
  4. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 22:07
  5. Using Multiple EEPROMs
    Last Post: - 27th March 2005, 07:37
