Hi Russ,
I was wondering if you could give me some advice on the 1700 series audio chips.
I have built a couple of proto crcuits using surface mount isd1740's in push button mode to start with. I can record, fast forward and play with out any problem.
I would like some tips on how to remove the pops at the start and end of the recording, along with the back ground hiss. Such as circuit design and layout to enable me to get the best from these chips. I have added a lm386 audio amp using an old winbond application sheet. I have both the main application sheets.
Any help to be very much appreciated.
kind regards Nick
P.s If any other forum members have some advice I would be please to hear from you too.
