Displaying temperature Setpoints
Hi Guys. I'm pretty new to picbasic pro. I've tried to create a temperature control system but having endless dead-ends. I've tried my best with the code and so far I managed to get the program to display the temperature. Adding in buttons though is what's giving me problems. Below is a copy of my program. Please help me somebody.
/Define LCD_DREG PORTB
Define LCD_DBIT 0
Define LCD_RSREG PORTB
Define LCD_RSBIT 5
Define LCD_EREG PORTB
Define LCD_EBIT 4
dEFINE LCD_BITS 4
DEFINE LCD_LINES 2
adval var word ' Create adval to store result
tempc var word ' Create tempc to store result
Setpoint var word
sethigh var byte
setlow var byte
Temp_Up var PORTC.0
Temp_Down var PORTC.1
High_sp var PORTC.2
Low_sp VAR PORTC.3
Main_disp VAR PORTC.4
TRISC = %11111111 ' Set PORTC to all input
ADCON1 = %10000010 ' Set PORTA analog and RIGHT justify result
ADCON0 = %11000001 ' Configure and turn on A/D Module
Pause 100 ' Wait 0.1 second
START:
if High_sp = 1 then gosub Set_High
IF Low_sp = 1 then gosub Set_Low
IF Main_disp = 1 then gosub Main
pause 10 '????????????? debounce how?
Keypress:
if Temp_Up = 1 then gosub Up_Loop
if Temp_Down = 1 then gosub Down_Loop
GOTO START
Main: ADCON0.2 = 1 ' Start Conversion
AGAIN: Pause 1
If ADCON0.2 = 1 Then AGAIN ' Wait for low on bit-2 of ADCON0, conversion finished
adval.highbyte = ADRESH ' Move HIGH byte of result to adval
adval.lowbyte = ADRESL ' Move LOW byte of result to adval
Lcdout $fe, 1 ' Clear screen
tempc=50*adval ' Conversion to Degrees
tempc=tempc/100
Lcdout "Temp = ",DEC tempc,$DF,"C" ' Display the value of temp
if Tempc > 100 then
lcdout "Out of range!"
if Tempc < 0 then
lcdout "Out of Range!"
Pause 1000 ' Wait 1 second
Goto Main ' Do it forever
Up_Loop:
If Temp_Up = 1 Then
Setpoint = Setpoint + 1
if Setpoint>100 then SetPoint=0
lcdout $fe, 1, "Setpoint = ", Setpoint
Pause 10
Else
Goto Keypress
Endif
Goto Up_Loop
Down_Loop:
If Temp_Down = 1 Then
Setpoint = Setpoint - 1
if Setpoint>0 then SetPoint=100
Pause 10
Else
Goto Keypress
Endif
Goto Down_Loop
Set_High: '?????????? Im trying to store the value
gosub Keypress '?????????? from the Temp_Up/Temp_Down.
write sethigh, Keypress '??????????
Set_Low: '?????????? Im trying to store the value
write setlow, Keypress '??????????
Still not paying attention...
Kalind
Does this make any sense? (Well to me it does) At the moment, nothing appears on the LCD. Please could somebody tell me what I need to add/delete to obtain success from this code.
i dont know..this isnt the main concern...lets get back to reality
The reality is that you don't read and/or follow thru your own code (or somebody else's code for that matter)...
If you did, you'd find at least 2 hard 'breaks' and 5 'bugs'...
