Number sorting algo that I spat out yesterday can sort 10,000 64 BIT numbers in 15 seconds on a PIII 866MHz. Considering the simplicity of it - this is fast! The code is in Visual Basic but shouldn't be too hard to port to PBP. I don't have time to do it at the moment, anyone up for it? If you feel that you have an even better solution, please post it here.
Code:Private Function Sort_Numbers(ByRef Num_Array)
' (An easy to get your head around algo)
Dim Compare_A As Long
Dim Compare_B As Long
Dim Swap As Long
Dim Array_Pos As Long
Dim i As Long
Dim j As Long
Dim k As Long
i = UBound(Num_Array) ' Size / last index of array
k = i ' Copy of i used to show progress - indexes sorted thus far
Do Until i = 0 ' Loop until entire list has been sorted
Compare_A = Num_Array(i) ' Load comparison var (starting at bottom of list)
For j = Array_Pos To i ' Try to find a bigger num (starting from top of list)
Compare_B = Num_Array(j) '
If Compare_B > Compare_A Then ' This num bigger?
Swap = Num_Array(i) ' Swap them
Num_Array(i) = Compare_B '
Num_Array(j) = Swap
Array_Pos = j '
Exit For ' Bail out, but we need to come back (might be an even bigger num)
End If
Next
If j > i Then ' Num is in correct pos - nothing bigger exists
i = i - 1 ' Move to next index
Array_Pos = 0
' Show user how many have been sorted so far (yes this will slow things down marginally)
Progress = "Sorted " & (k - i) & " numbers"
DoEvents
End If
Loop
End Function
