Your cascaded counter for scrolling message
Please explain the use of D3 through D7 do make an 'or gate' for reset. Why 100K resistors?
Why not use Q0 from each of the CD4017 counters?
Sorry For A Foolish Question!!!
HELLO T JACKSON, YOUR PROJECT IS INSPIRING AS IF TO SAY CHALLENGING SO MANY PEOPLE AROUND THE WORLD. I WANT TO BUILD THIS PROJECT AND MAGUS SITE TENDS NOT TO OPEN AND IT IS LIKE IT IS NOT IN ENGLISH(SORRY TO MAGU IF I AM WRONG). I AM THOUGH A NEWBIE TO PIC IN SOME SENSE BUT HAVE BEEEN PLAYING WITH ANALOG ELECTRONICS FOR SOMETIME. WHAT I DONT REALLY UNDERSTAND IS THE EEPROM ASPECT OF YOUR PROJECT, I WANT TO KNOW HOW YOU LOAD THE ASCII CHARACTER SET INTO THE EEPROM FROM YOUR PROGRAM, OR ARE YOU NOT USING THAT METHOD. I WAS THINKING OF DEFINING EEPROM ADDRESSES FOR ASCII CHARACTER AND THEN LOADING EACH CHARACTER IN AN ADRESS THAT I WILL LATER READ TO DISPLAY CHARACTER. DO YOU HAVE ANY DETAIL MATERIALS ON HOW TO USE EERPOM LIKE THE ONE YOU USED IN THE PROJECT? HOW FAST REALLY DO YOU FETCH DATA FROM THIS EEPROM . I AM THINKING OF BUILDING A BIGGER DISPLAY USING 3mm ULTRABRIGHT LED WITH BUFFER AND SUPPLYING ABOUT 50ma OF CURRENT WITH MULTIPLEXING I DONT THINK THE LEDS WILL GET DAMAGED? SORRY REALLY IF MY QUESTION MAY BE TOO SIMPLE FOR YOU TO REPLY TO?
IS THERE ANYWAY I CAN GET MAGU'S LINK AND DOWNLOAD HIS STUFF. THANKS.
programming different displays
Trent,
I am also designing a similar scrolling sign. I am storing the entire character set in the PIC program memory. I then plan to fetch the characters out by switches to build a buffer that contains the message. Any insight on this approach? Did you look at this approach?
