fratello
Thanks for support !!!!
First code (post #18) return this result : 28 CA C6 48 1 0 0 A7
Second code (post # 22) return : CA C6 48 01 00 00
In the code that I write now I use something like this :
"Init1
OWOut DQ, 1, [$55, $28, $FE, $DA, $3E, $0, $0, $C1, $4E, $FF, $FF, $7F]
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $48]
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $B8]
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $BE]
Pause 1000
OWOut DQ, 0, [Temperature.Byte0, Temperature.Byte1, 0, 0, DS18B20_12bit]
Init2
OWOut DQ, 1, [$55, $28, $FE, $DA, $3E, $0, $0, $C1, $4E, $FF, $FF, $7F] 'SENSOR 2 !!!!!!!!! not reading yet !!!!
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $48] 'SENSOR 2 !!!!!!!!! not reading yet !!!!
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $B8] 'SENSOR 2 !!!!!!!!!
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $BE] 'SENSOR 2 !!!!!!!!!
Pause 1000
Main
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $44] ' Start temperature conversion Sensor 1
WaitLoop:
While not DQ
Wend
OWIn DQ, 0, [Temperature.Byte0, Temperature.Byte1]
GoSub Convert_Temp
GoSub DisplayTemp
Part2
OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $44] ' Start temperature conversion Sensor 2
WaitLoop2:
While not DQ
Wend"
I hope it's good...will see !
