Skimask here is the entire program for both sides:
TRANSMITTER
INCLUDE "MODEDEFS.BAS"
@ DEVICE PIC16F628a,XT_OSC
@ DEVICE pic16F628a, WDT_OFF
@ DEVICE pic16F628a, PWRT_ON
@ DEVICE pic16F628a, MCLR_ON
@ DEVICE pic16F628a, BOD_ON
@ DEVICE pic16F628a, LVP_OFF
@ DEVICE pic16F628a, CPD_OFF
@ DEVICE pic16F628a, PROTECT_OFF
define osc 4
CMCON=%00000111
trisb = %11111111
trisa = %00010111
chk_sum var byte
dgood var porta.2
serpin var porta.3
nokey con %11111111
synch con 254
address con %00000001
keyin var portb
keydata var byte
E VAR PORTB.0
D VAR PORTB.1
G VAR PORTB.2
A VAR PORTB.3
B VAR PORTB.4
C VAR PORTB.5
F VAR PORTB.6
na VAR PORTB.7
PreAmble CON $A5 ' 10100101 preamble
findkey:
if keyin != nokey then dout
goto findkey
pressed:
if A= 0 then pause 10
if A= 0 then keydata = %01010110
if B = 0 then pause 10
if B = 0 then keydata = %01011001
if C = 0 then pause 10
if C= 0 then keydata = %01011010
if D = 0 then pause 10
if D = 0 then keydata = %01100101
if E = 0 then pause 10
if E = 0 then keydata = %01100110
if F = 0 then pause 10
if F = 0 then keydata = %01101001
if G = 0 then pause 10
if G = 0 then keydata = %01101010
dout:
gosub pressed
low dgood
chk_sum = (address + address)
chk_sum = chk_sum + (keydata + keydata)
goto transmit
transmit:
serout serpin,N2400,[$55,$55,$55,$55,$55,$AA,$AA,$AA,$AA,$AA,synch,addr ess,address,keydata,keydata,chk_sum]
if keyin = nokey then pause 10
if keyin = nokey then x2
goto findkey
x2:
high dgood
keydata = %00000000
goto findkey
RECEIVER
mydata1 VAR byte
mydata2 var byte
address1 var byte
address2 var byte
checksum var byte
chk_sum var byte
serpin VAR porta.1
PORTA = 0
PORTB = 0
trisa = %00000010
trisb = %10000000
CMCON=%00000111
PAUSE 50
loop:
clear
gosub loop1
CheckSum = (address1 + address2)
CheckSum = CheckSum + (mydata1 + mydata2)
IF checksum != chk_sum THEN loop
IF (mydata1) != (mydata2) THEN loop
IF (address1) != (address2) THEN loop
if mydata1=%01010110 then rly1
if mydata1=%01011001 then rly2
if mydata1=%00000000 then rly2
if mydata1=%01011010 then rly3
if mydata1=%00000000 then rly3
if mydata1=%01100101 then rly4
if mydata1=%00000000 then rly4
if mydata1=%01100110 then rly5
if mydata1=%00000000 then rly5
if mydata1=%01101001 then rly6
if mydata1=%01101010 then rly7
rly1:
if mydata1=%01010110 then pause 10
if mydata1=%01010110 then toggle 0
pause 10
goto loop
rly2:
if mydata1=%01011001 then pause 10
if mydata1=%01011001 then high 1
if mydata1=%00000000 then low 1
goto loop
rly3:
if mydata1=%01011010 then pause 10
if mydata1=%01011010 then high 2
if mydata1=%00000000 then low 2
goto loop
rly4:
if mydata1=%01100101 then pause 10
if mydata1=%01100101 then high 3
if mydata1=%00000000 then low 3
goto loop
rly5:
if mydata1=%01100110 then high 4
if mydata1=%00000000 then low 4
goto loop
rly6:
if mydata1=%01101001 then pause 10
if mydata1=%01101001 then TOGGLE 5
pause 10
goto loop
rly7:
if mydata1=%01101010 then pause 10
if mydata1=%01101010 then TOGGLE 6
pause 10
GOTO loop
loop1:
SERIN2 serpin,16780,[wait(254),address1,address2,mydata1,mydata2,chk_su m]
No LCD, I do have leds and also monitoring the pins with scope.
thanks
