Hi Fredrick,
Double check that your LCD ground is connected to the PIC Vss (5V common) securely.
Check that your LCD Plus is connected to the PIC Vdd (5V plus).
Also check resistor pullup on PIC MCLR to Vdd. as Skimask suggested.
-Adam-
Hi Fredrick,
-Adam-
MCLR pull up is ok.
The LCD is connected to the same voltage regulator as the PIC but not directly connected to the VDD or VSS PIC pin.
The LCD is connected to this DEV board.
http://www.olimex.com/dev/pic-p28.html
The LCD does not have a backlight becouse itīs an (HD44780) OLED
For 2 years or so i use the same OLED whit an 16F84 and the same code to and then i worked
No it has not an heat sink, but it is capable of 1.5 A whitout an heat sink and that is more then i need.
http://www.fractronics.com/oled1_b.jpg
Hi Fredrick,
The LM317 package would be rated at 1.5A with a very good heat-sink and the correct input voltage, to avoid, dropping too much voltage and heating itself.
(input output differential V)
http://cache.national.com/ds/LM/LM117.pdf
With no heat sink, 15 V input 5 V output, the 317 could overheat with just over 200 mA at 25 C.
Regulator Heatsink Calculator
http://www.ef-uk.net/data/heatsinking.htm
How much current does the OLED LCD display draw?
Is the voltage regulator getting hot (to your touch)?
Can you oscilloscope the +5V supply? Watch for the voltage to dropout.
-Adam-
Ok thanx
The VR is not getting hot.
Edit: Heat sink is added just in case...
http://www.elfa.se/elfa-bin/dyndok.p...dok=245171.htm
Hi, Fredrick
Why not send us you REAL scheme ??? ... and may be a link to your Oled Datasheet ( couldn't find anything about it yet ...)
looking at various OLED displays Datasheet it seems :
DEFINE LCD_COMMANDUS 4500
DEFINE LCD_DATAUS 150
are the values to use ... not so fast, those OLEDs !!!
