Yup - works here too - using a JR X3810 transmitter and cheap and chearful GWS RX
We got there in the end ;)
I've changed your code a bit to make a simple RC Switch that turns on GPIO.1 in real time (ie activate the switch on the TX and the LED lights or goes out)
I've also removed some parts that are not needed (input GPIO.3 for example as PULSIN automatically makes the pin an input)
Good result for the end of the day.Code:'12F675
@ __CONFIG _INTRC_OSC_CLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
OPTION_REG.5 = 0
Pulselen var Byte
HighCode Var Byte
LowCode Var Byte
clear
highcode = 0 ' setup vars to be changed
lowcode = 200 ' setup vars to be changed
ReadPWM:
PulsIn GPIO.3, 1,Pulselen
If pulselen > highcode then Highcode = Pulselen
If pulselen < LowCode and Pulselen > 50 then Lowcode = Pulselen
if (Pulselen + 20) >= highcode then High GPIO.1
If (Pulselen - 20) <= LowCode Then low GPIO.1
GoTo ReadPWM
There ya go thanks for the help didn't notice the 2nd page or would have replied sooner :)
