Energy Conservation:Tele-Commuting
How many people could realistically Telecommute for the majority of their workweek ?
Myself being primarily a Field Technician of sorts don’t see it happening. . .
Client on the phone: “You want ME to unplug the system from the wall, take a SCREWDRIVER and do WHAT?”
One “US” PC manufacturer Headquartered in TEXAS, tried that for a while, they may still, I don’t know,
I once worked for a company who contracted a LOT of their Field Service Warranty Work.
Remote Control repair of PC systems, requiring component replacement, generally doesn’t work well.
The AVERAGE End User of a PC can't (or just will not) count the Pins on a DB25 Connector.
If you are at all technically adept and you are calling a PC company’s help desk for technical support,
the first thing you should say is “Put the SCRIPT Down, Get Me Tier Two!”
"Science reveals secrets of invisibility"
Originally Posted by Melanie
I've borrowed a Klingon cloaking device...
In a few years, you will no longer need borrow that device. You will just buy one!
http://www.cnn.com/2006/TECH/science...ity/index.html
Thanks to nano tech and to the people who are able to play with it.
WOW ! Interesting Concept
Nuclear Powered Refrigeration . . .
Now THAT is a subject, which just screams for SERIOUS R&D money to be thrown at it.
Did we just solve global warming? . . . OK, so where IS Osama Bin Ladens hideout?
Ahhhh, mysteries of Thermodynamics ...
Hi, F Lez
< I have a refrigerator, and only a month ago I was discussing with the wife about moving it from out the kitchen into the back yard so its no longer working like an indoor heat pump >
Sorry, but it is really a false assertion ...
The heat you pump in the room ( entering the fridge ) ... you bring it to the backside of the fridge ... so, IN THE ROOM !!! , just adding the compressor running electric energy.
Globally ... you heat your room !!!
So, ... a split system is the solution for summer, and a conventional one for the winter .
Nothing Lost, Nothing created ... just ever reducing Entropy
Originally Posted by f_lez
but if its a 150w motor, its a 150 watt of heat going into the air, minus electrical energy thats converted to noise.
Noooooo,
Noise is also a kind of energy ( pressure ); it is also converted IN YOUR ROOM, into heat. ( supposing you do not hear your fridge from outside ... let's keep serious ... ).
But note this amount of energy is ... ridiculous !!!
so, split system ... and compressor outside the room !!!
to JOE
" Check the 12th Green in Palm Springs. He probably has a house right there."
May be, May be, ... but he's got a much better protection : OIL !!!
