Yes, this is correct pin-out. Pin 6 should be connected to +5 via some resistor (say, 1k). If grounded, output will be disabled.
Note that this code only handles 26-bit wiegand format. As much as i am aware, HID readers output 36 bits. In this case data will be rejected :(
I do have a combo lock project for 36-bit HID readers but try first this code. If it does not work, I'll publish the other one. Or- you have the source, you could modify it by yourself also. And estonian learn estonian via my comments :) Actually, it's good you probably do not understand it...bad style... ;)
