Re: Trying to inch my way to the finish line w/ a 16F1829.........
thasatelliteguy
then maybe i did get it working... I got consistent gibberish at one point. I'm beginning to regret ever getting away from arduino. At least it could walk and chew gum at the same time which apparently pic cannot.
You said you got it working by using Hserin. Now you do not seem to be sure.
I'm sorry guys. I was very very tired. I have a crazy learning curve, and sometimes when I push wide-open-throttle for too long cuz I've really bitten off too much, I burn out and crash. I've been asleep since Saturday... five weeks was just too long. I really do appreciate all the help! You all are great!
Can I use EUSART over BT HC-05? I would assume not since one is UART and one is EUSART...
If that's the case my problem is then:
1. I cant use DT's interrupts without corrupting my serin/serout. And I have to assume it'll corrupt hserin/hserout as well.
2. I can't use ON INTERRUPT cuz it'll miss pulses during even the shortest waits. This is even worse than #1 since the machine will be lost.
If I use serial interrupts and program loops, which from how arduino is structured, I assume that's what happens on that platform, wouldn't that solve my problem once and for all?
EarlyBird2
No I never got it working using hserin. I can't even get multicalc to run. I DID get some rather consistent gibberish through hserin, but nothing more.
thasatelliteguy
So are you saying you have got nothing to work? If this is the case then chose something and make it work. Henrik has suggested Hardware USART.
If what you do does not work then you are doing something wrong. Do not apportion blame elsewhere.
I may be wrong, but the only difference between SERIN and HSERIN is one is handled by software, the other by hardware. But the actual signal is identical, bluetooth shouldn't be able to know or care how it was generated.
Multicalc, you need a DLL possibly. It's in that thread. It works on my XP and WIN7 machines. You REALLY want to get this tool working, it does other things as well as the USART settings.
If an Arduino can do something, I don't see a reason why a PIC couldn't do it.
One difference is that Hardware USART requires an RS-232 driver but software does not. Also with software the pins are not fixed. Just need to take this into account when deciding which to use. Obviously if there is no RS-232 driver available then Hardware USART can not be used. I wonder if this is why he could not get HSERIN to work, could explain the gibberish he got.
Might be on to something. I forgot I use a MAX232 in my setup.
PC side uses more than 5V (12V I think), good thing a PIC can take a beating.
EarlyBird2
One difference is that Hardware USART requires an RS-232 driver...
Look what I found.
http://www.picbasic.co.uk/forum/show...2591#post82591
Demon
Jury's still out on the beating... I toast them at regular intervals doing far less nefarious acts to them.... However, they are, on whole, much cheaper to replace than arduino boards.
As far as the 12v tho, this 16f1829 chip I'm using now has been a hoss so far. And it started life as a PICAXE20M2. So when I first flashed it, it was with a home-made serial cable with no MAX232 or anything. Just straight out the serial port to the chip, so I think some chips will handle it better than most think...
thasatelliteguy
Have you a MAX232 connected to the Hardware USART pins?
If SEROUT works with the HC-05 then HSEROUT will - as long as you get the polarity and baudrate correct. USART vs EUSART is just a matter of the features available they both do asyncronous serial and they both work with HSERIN/HSEROUT.
That's correct and it's just the nature of the beast basically. It's not a problem, issue or bug, it's just the way the microcontroller works. If it's sitting in a tight software timed loop (which SERIN is) and an interrupt forces it to go and do something else the timing of that tight software loop is thrown off - nothing you can do about that.
That's also correct due to the reasons described earlier.
Well, that depends..... For cabled connection to a PC it's a good idea to use a RS232 tranceiver for several reasons. Normally, the polarity of the USART output on the PIC is inverted in respect to what the PC expects. A typical RS232 tranceivers does two things. It "boosts" the signal voltage leverl so it falls within the specs for a proper RS232 connection and it inverts the signal so the PC can read it correctly.
Now, since we're talking about a Bluetooth connection here and it does work with SEROUT I probably wouldn't want to put a MAX232 between the PIC and the bluetooth module since it's most likely designed to operate at TTL levels. However, and as has been pointed out before, you need to watch the polarity and make it match whatever you're using with SEROUT. Either invert in in the PIC (if it's got that option) or use an external inverter between the PIC and the Bluetooth module.
Take a step back, write a small test program just for the HSEROUT/HSERIN part and get that working.
OK. I got multicalc working.
I got hserout working.
hserin - notsomuch.
My menu looks fine in the terminal. (although I can't test it with interrupts firing since I can't respond and mover the dish) But it just sits there and looks at me stupid when I give a command.
'* Name : UNTITLED.BAS *
'* Notice : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 6/7/2014 *
'* Version : 1.0 *
'* Notes : *
INCLUDE "DT_INTS-14.bas"
INCLUDE "ReEnterPBP.bas"
DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
APFCON0.2 = 1
APFCON0.7 = 1
__config _CONFIG1, _FOSC_HS & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF
__config _CONFIG2, _PLLEN_OFF & _LVP_OFF
DEFINE OSC 20
ANSELA = 0
ANSELB = 0
INT_Handler INT_INT, _doEncoder, PBP, yes
@ INT_ENABLE INT_INT
LED var PORTC.7
TRISC.7 = 0
LED = 0
DOWN var PORTB.4
TRISB.4 = 0
DOWN = 0
EAST var PORTB.5
TRISB.5 = 0
EAST = 0
WEST var PORTB.6
TRISB.6 = 0
WEST = 0
TRISC.5 = 1
UP var PORTB.7
TRISB.7 = 0
UP = 0
a0 var byte
a1 var byte
e0 var byte
e1 var byte
i var byte
VerboseMode var byte
cereal var byte
Aencoder0Pos var word
Eencoder0Pos var word
VerboseMode = 1
goto MainMenu
doEncoder:
if UP = 1 then
'if e0 = 5 then
Eencoder0Pos = Eencoder0Pos + 1
' e0 = 0
if VerboseMode = 1 then Hserout ["Eencoder0Pos = ", #Eencoder0Pos, 13, 10]
'endif
'e0 = e0 + 1
if DOWN = 1 then
'if e1 = 5 then
Eencoder0Pos = Eencoder0Pos - 1
' e1 = 0
'endif
'e1 = e1 + 1
if EAST = 1 then
if a0 = 5 then
Aencoder0Pos = Aencoder0Pos + 1
A0 = 0
if VerboseMode = 1 then Hserout ["Aencoder0Pos = ", #Aencoder0Pos, 13, 10]
a0 = a0 + 1
if WEST = 1 then
if a1 = 5 then
Aencoder0Pos = Aencoder0Pos - 1
a1 = 0
a1 = a1 + 1
@ INT_RETURN
MainMenu:
gosub CLR
HSEROUT ["******** MAIN MENU ********", 13, 10, 10]
HSEROUT [" 1. Start Homing Sequence", 13, 10]
HSEROUT [" 2. Manual JOG Mode", 13, 10]
HSEROUT [" 3. Auto-Acquire Satellite", 13, 10]
HSEROUT [" 4. Stow Dish for Travel", 13, 10, 10]
HSEROUT ["Enter Your Selection:"]
hSERIN [cereal]
if VerboseMode = 1 then HSEROUT [#cereal,13,10]
' If cereal = "1" then goto HomeDish
If cereal = "2" then goto JogMenu
' If cereal = "3" then goto TEST1
' If cereal = "4" then goto Startup
goto MainMenu
JogMenu:
gosub CLR
pause 250
HSEROUT ["***** JOG MENU *****", 13, 10, 10]
HSEROUT ["U - UP", 13, 10]
HSEROUT ["D - DOWN", 13, 10]
HSEROUT ["E - EAST", 13, 10]
HSEROUT ["W - WEST", 13, 10]
HSEROUT ["S - ALL STOP", 13, 10]
HSEROUT ["X - MAIN MENU", 13, 10, 10]
hSERIN [cereal]
if cereal = "U" Then
gosub allSTOP
HIGH UP
if cereal = "D" then
gosub allSTOP
HIGH DOWN
if cereal = "E" then
gosub allSTOP
high EAST
if cereal = "W" then
gosub allSTOP
HIGH WEST
if cereal = "S" then gosub allSTOP
if cereal = "X" then
gosub allSTOP
goto MainMenu
goto JOGMenu
allSTOP:
EAST = 0
UP = 0
DOWN = 0
WEST = 0
if VerboseMode = 1 then GOSUB POS
CLR:
if VerboseMode = 0 then
For i = 0 to 30
HSEROUT [10]
next i
abort:
gosub allSTOP
gosub clr
HSEROUT ["USER STOP! -- MOVE ABORTED!", 13, 10]
PAUSE(5000)
goto MainMenu
moveerror:
gosub allSTOP
gosub clr
HSEROUT ["SYSTEM ERROR! -- MOVE ABORTED!", 13, 10]
PAUSE(5000)
goto MainMenu
POS:
HSEROUT [" EL -- ", #Eencoder0Pos, " AZ -- ", #Aencoder0Pos, 13, 10]
pause 2000
Are you saying these lines do not execute?
hSERIN [cereal]
thasatelliteguy
HSERIN is not receiving anything then?
EarlyBird2
that's correct
The issue has nothing to do with HSERIN or the program. As you have a MAX232 could you connect direct to your PC and use HyperTerminal to test the functioning?
have a look at this thread for some ideas on serial transmission with interrupts
http://support.melabs.com/threads/28...terrupt-Serial
The BT modules could be the issue have they got Flow Control on the RS232. A data sheet would help.
If SERIN/SEROUT without flow control works across the BT-link (which it apparently is) then HSEROUT/HSERIN will work too. It's just a matter of getting it setup correctly.
Having an oscilliscope or logic analyzer and probing the signals as it enters/exits the PIC would help. Doing so with the "working" version using SEROUT/SERIN and the with the HSEROUT/HSERIN comparing what you get would most likely reveal the issue.
My understanding is that serin never worked but serout did, post #44, which is why I suspect flow control, we were given the wrong impression when we were told using hardware usart had solved the problem. Do we need more information? or will this lead to more misinformation depending on how I read it.
HenrikOlsson
Flow control.... hmmmm. Makes me think I may have somethiny else amiss... could it be terminal settings? Serin/serout works fine. I have hooked up an LED to the rx on the pic and I see it flicker on data send. I havent tried to cross the tx/rx to look for echo but I suspect ill get it. Was there something I needed to change in the terminal program to make the data "legit" ? I seem to remember a flow control dropdown box......
I suppose I can also scope the data coming out of the bt and into the pic, but I dont think itll yield much more than seeing the led flicker... unless you want me to somehow capture and post the raw scope results to actually interpret them
I'll be back home in about an hour if you would like me to do that...
The flow control I was thinking of was between the 16f1829 and the BT connected to it.
OK! I think I have my permanent solution. Since I had no problems with the first setup I did with this project where I was using physically attached buttons instead of serial commands to control the unit, I am adding a second PIC, whose only job in life is to sit at a serin command pause and await commands. Upon receiving a command, it will simply set a pin high for about 100ms, simulating a button press. Proof of concept already works... Just have two small snags... (and a large one too, but one step at a time lol)
1. I am trying to send via serial just one character. Capital A-F, depending on what combo of buttons is pressed by the user. It's not going thru. The BT is linked. The link seems good. When I hold a button down, it causes the serin pause to release, causing my debugging LED to flash. However, no command is processed. I'm sure it's a format problem or something, but I have tried 9 ways to sunday and I just can't seem to spot what I'm doing wrong. Also, if I shut down the master BT and log my laptop terminal into the dish PIC, sending A-F from the terminal works perfectly and it responds as expected.
2. Only buttons 3 and 4 work. Buttons 1 and 2 do not cause the LED to flash on the receiving end. I assume I'm missing something again about analog/digital, but this pic is very basic and has no ADC, and for the life of me I cannot figure out what I am missing. I have read thru every register in the datasheet, and I'm just not snapping to what it is...
Here is the code for the handheld device:
'* Name : Wireless Handheld Device
'* Author : John Moore
'* CHIP : PIC16F628A
'* Date : May 28, 2014
'* Version : 1.0
'* Notes : This pic will eventually have 4 physical buttons and an LCD
'* : as well as a BT device. Right now I just need it to send the
'* ; serial commands, as I am monitoring the feedback with a terminal.
__config 10000111110000
button1 var PORTA.2
button2 var PORTA.3
button3 var PORTA.4
button4 var PORTB.3
TRISA.2 = 1
TRISA.3 = 1
TRISA.4 = 1
TRISB.3 = 1
cereal var byte
TX var PORTB.2
TRISB.2 = 0
START:
if button1 = 1 then cereal = "A"
if button2 = 1 then cereal = "B"
if button3 = 1 then cereal = "C"
if button4 = 1 then cereal = "D"
if (button2 = 1) and (button3 = 1) then cereal = "E"
if (button1 = 1) and (button4 = 1) then cereal = "F"
if cereal <> "X" then serout TX, 2, [cereal]
cereal = "X"
GOTO START
Here is the code for the PIC16F628A that is receiving the commands and "pressing buttons":
'* Name : On-Board Communication PIC
'* Version : 1.0
'* Notes : This pic will never be more complicated than this. It's only
'* : purpose in life is to get characters and push buttons.
button1 var PORTB.7
button2 var PORTB.6
button3 var PORTB.5
button4 var PORTB.4
TRISB.7 = 0
TRISB.6 = 0
TRISB.5 = 0
TRISB.4 = 0
button1 = 0
button2 = 0
button3 = 0
button4 = 0
RX var PORTB.3
TRISB.3 = 1
LED var PORTA.1
TRISA.1 = 0
cereal var byte
START:
serin RX, 2, cereal
if cereal = "A" then
high button1
pause 140
low button1
if cereal = "B" then
high button2
pause 140
low button2
if cereal = "C" then
high button3
pause 140
low button3
high button4
pause 140
low button4
button2 = 1
button3 = 1
pause 140
button2 = 0
button3 = 0
if cereal = "F" then
button1 = 1
button4 = 1
pause 140
button1 = 0
button4 = 0
LED = 1
pause 250
LED = 0
pause 250
GOTO START
bit 7 of your config word should be 0 , having lvp enabled can lead to tears .
the comparator needs to be disabled to use your porta pins as digital
So you have your BT sorted out?
I use a BT chip on my boards with no converter. I have the BT chip running at 3.3v just like the PIC.
I am not sure what you are meaning by handheld device but if you are using a BT chip, look into making the app work on your Android phone.
Look into Basic4Android. Its a piece of cake to use. The wireless side is a bit cumbersome but once you get it going, its pretty slick. I use it to make an app to control up to 48 electrical motors sending data back and forth from the motor control boards to a tablet all wirelessly.
http://www.basic4ppc.com/index.html
If you get try it and need some help, email me at [email protected]
richard
A thousand thank-yous my friend! It worked beautifully!
