Hi dave, does that code work?? you have $A0 for both read and write cycle .. I thought it was write $A0 and Read $A1
K
K
It works, I have it running on a bread board right now.
PBP takes care of flipping that bit for you.Quote:
I am looking over you pic pin configuration for the SDA and CLK pins but and you have them on DPIN VAR PORTB.2 'I2C DATA PIN
CPIN VAR PORTB.1 'I2C CLOCK PIN
What is the purpose of having SDA, CLK pins on the chip if we can use any port. Unless I am reading another chip besides the PIC18F6680.
I also how do you make the difference between writing to the RTC and writing to the DS1337 then ?
K
The hardware ports are good for hardware interrupts and maybe a little speed. But I have not noticed much speed wise myself.Quote:
I think you mean writing to the RTC and EEPROM...Quote:
It IS in the Control-Address part of the command as you mentioned earlier from the post Mel did.
The EEPROM used $A0 for the Control and a value for the location where the data is stored. In my code it is the VAR ADDR.
The RTC uses %11010000 for the Control and $00 for the Address part. The big thing is the control byte.
I2CWRITE DPIN,CPIN,$A0,ADDR,[DATO] 'EEPROM
I2CREAD DPIN, CPIN, RTC, SecReg, [sec,mins,hr,day,date,mon,yr]
Hi
thanks you for the hand. I still do not what is wrong with my code. I will work on it tonight. Your code does work on my chip with both RTC and EEPROM chip. thank you again. I corrected a few things with my code, but I cannot getthe full thing working. What is odd is that if I run my program, first thing I do is press PORTC.7 to LCDout, I see the time I put in the RTC, but if I do it again it shows me only 255 255 255 ...
K
Ouff, ok I got it narrowed down now to one function, and I really really would like to know why it is not working. Here is the mainloop that is not working, the red part is where the differences are, The output is always FF.
and is is the working good, looks similar, but in the none working code I need a loop.Code:Mainloop:
lcdout $FE,1, "Appuye sur Record"
lcdout $FE,$C0, "ou sur Show"
if PORTC.6 =0 then
GOSUB READ_RTC
I2CWRITE DPIN,CPIN,$A0,Write_Address,[sec]
Write_Address = Write_Address +1
PAUSE 10
I2CWRITE DPIN,CPIN,$A0,Write_Address,[mins]
PAUSE 10
I2CWRITE DPIN,CPIN,$A0,Write_Address,[hr]
PAUSE 10
Battery_Charge_Counter = Battery_Charge_Counter + 1
Endif
if PORTC.7 =0 then
bat =0
For i=0 to 2
I2CREAD DPIN,CPIN,$A0,bat,[sec,mins,hr]
PAUSE 10
LCDOUT $FE,1," Time ",DEC3 i+1
LCDOUT $FE,$C0,"AD",DEC Write_Address,":", HEX2 hr, ":", HEX2 mins, ":", HEX2 sec
PAUSE 1000
bat = bat+3
next i
Endif
GOTO Mainloop
Code:Mainloop:
if PORTC.6 =0 then
GOSUB READ_RTC
PAUSE 10
PAUSE 10
PAUSE 10
Endif
if PORTC.7 =0 then
Write_Address = 0
I2CREAD DPIN,CPIN,$A0,Write_Address,[sec,mins,hr]
PAUSE 10
LCDOUT $FE,1," Time ",DEC3 1
LCDOUT $FE,$C0,"AD",DEC Write_Address," T:", HEX2 hr, ":", HEX2 mins, ":", HEX2 sec
PAUSE 1000
Endif
GOTO Mainloop
If this is for reading the RTC
then $A0 is the problem.
NO uts reading the EEPROM.
When PORTC.6 =0 I record from RTC to EEPROM
And when PORTC.7=0 I show on LCD what has been recorded to EEPROM
The only time I read RTC is in the first option C.6 using your routine GOSUB READ_RTC, that works fine.
The program works, but if I add an IF loop it do not work ( red code above)
I think this has been the problem since the beginning !
K
IS it possible to write a byte at a time on the EEPROM. From the document, 2 byte ( a word is written for teh address, but I guess this is at the same place..) and the internal clock is incremented. Maybe after writting, the internal clock did not reset and when reading it keeps incrementing where it left off !?!....
Just a thought
.... I think the address has to be a word, not a byte. will try it tonight.
K
OK it is now working.. somewhat, Needed to put a word instaed of a byte for the address. Now its more of a programming issue which I am stuck with. The lcd is showing recoded time, but the time does not seem to follow a normal clocking. I record at 5 sec interval, and the first three times are identical, then the next two are 15sec later but are the same...
Code:Mainloop:
if PORTC.6 =0 then
GOSUB READ_RTC
I2CWRITE DPIN,CPIN,$A0,Write_Address,[sec,mins,hr]
Write_Address = Write_Address +3
Endif
if PORTC.7 =0 then
bat = 0
j=1
for i =0 to Battery_Charge_Counter/3
PAUSE 10
LCDOUT $FE,1," Time ",DEC3 j
LCDOUT $FE,$C0,"WA",DEC Write_Address," T:", HEX2 hr, ":", HEX2 mins, ":", HEX2 sec
PAUSE 2500
bat = bat +3
j = j+1
next i
Endif
GOTO Mainloop
READ_RTC:
I2CREAD DPIN, CPIN, $D0, SecReg, [sec,mins,hr,day,date,mon,yr]
pause 10
SET_RTC: ' Do once at startup
yr = $3
mon = $5
date = $05
sec = $09
mins = $05
hr = $03
I2CWRITE DPIN, CPIN, $D0, SecReg, [sec,mins,hr,day,date,mon,yr]
Ok,
The chips are working but my outputs are erronous. I just want to record time, store it, and then replay it. I am getting all kinds of numbers on the LCD.
here is my latest code:
Code:'/////////////////////////
'// DS1337 and test program
'// Using the PIC16F887
'// From Dave Mackarit FUNCTIONAL
'// Define section //
'@ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
OSCCON = %01110000 '8 Mhz
DEFINE OSC 8
ANSELH = 0
'// LCD configuration //
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus RB.4, RB.5, RB.6, RB.7
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
DPIN VAR PORTC.4 'I2C DATA PIN
CPIN VAR PORTC.3 'I2C CLOCK PIN
Write_Address VAR WORD
i var byte
j var byte
bat var byte
Battery_Charge_Counter var byte
' -------------- RTC definitions -----------------
RTC CON %11010000
SecReg CON $00 ' seconds Write_Addressess (00 - 59) ' MSB of SecReg must be set to a 0 to enable RTC
ContReg CON $0E ' control register
cntrl CON %00000000 ' sets the SQW/OUT to 1Hz pulse, logic level low
I2CWRITE DPIN, CPIN, RTC, ContReg, [cntrl]
' The variable below holds the values entered:
' entered by the user
sec VAR BYTE : mins VAR BYTE : hr VAR BYTE : day VAR BYTE :date VAR BYTE : mon VAR BYTE : yr VAR BYTE
Battery_Charge_Counter = 0
PAUSE 1000
GOSUB SET_RTC
Write_Address = 0
Mainloop:
if PORTC.6 =0 then
GOSUB READ_RTC
Write_Address =0
PAUSE 10
Write_Address = Write_Address +7
Endif
if PORTC.7 =0 then
bat = 0
j=1
for i=0 to Battery_Charge_Counter
PAUSE 10
LCDOUT $FE,$C0,"time ",DEC Battery_Charge_Counter,":", HEX2 hr, ":", HEX2 mins, ":", HEX2 sec
PAUSE 2000
bat = bat +7
j= j + 1
next i
Endif
GOTO Mainloop
READ_RTC:
yr = $3
mon = $5
date = $05
sec = $09
mins = $04
hr = $02
Here you are always writing starting at Address 0. The ADD 7 is always being reset.
Unless I am missing something.Code:if PORTC.6 =0 THEN
GOSUB READ_RTC
Write_Address =0
PAUSE 10
Endif
Ok that was not my latest one ...sorrryy !!
here it is:
Gining me very eronnous time (ie FF)
DEFINE OSC 8
ANSELH = 0
bat var byte
i var byte
j var byte
RTC CON %11010000
PAUSE 1000
GOSUB SET_RTC
Write_Address = 0
Mainloop:
if PORTC.6 =0 then
GOSUB READ_RTC
PAUSE 10
Endif
if PORTC.7 =0 then
bat = 0
j = 1
PAUSE 10
PAUSE 1000
bat = bat + 7
j = j + 1
next i
Endif
GOTO Mainloop
READ_RTC:
yr = $3
mon = $5
date = $05
sec = $09
mins = $04
hr = $02
I could not see the problem with your code so I made a test myself.
When the EEPROM address reaches 255 the data read back for Min and Sec is FF.
Must be crossing the boundary of rolling over because the EEPROM is full?
It has been a long day and I am getting my bits and bytes and K and k mixed up.
Anyone wants to clear me up we are using
http://www.microchip.com/wwwproducts...cName=en024639
Here is my test
Code:'FL PIC18F6680
' 18F6680(PIC) 24FC1025(EEPROM) DS1337C(RTC)
DEFINE OSC 20
@ __CONFIG _CONFIG1H, _OSC_HS_1H
@ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
@ __CONFIG _CONFIG4L, _LVP_OFF_4L
DEFINE LCD_DREG PORTG
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTE
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 1
DEFINE LCD_BITS 4
DEFINE LCD_LINES 4
DEFINE LCD_COMMANDUS 3000
DEFINE LCD_DATAUS 150
ADDR VAR WORD
DATI VAR BYTE
DATO VAR BYTE
RTC CON %11010000
SecReg CON $00 ' seconds address (00 - 59) ' MSB of SecReg must be set to a 0 to enable RTC
sec VAR BYTE ' seconds
mins VAR BYTE ' minutes
hr VAR BYTE ' hours
day VAR BYTE ' day
date VAR BYTE ' date
mon VAR BYTE ' month
yr VAR BYTE ' year
Esec VAR BYTE ' seconds
Emins VAR BYTE ' minutes
Ehr VAR BYTE ' hours
I VAR BYTE
PAUSE 1000
'GOSUB SET_RTC
RUN:
ADDR = 0
'SAVE DATA
FOR I = 0 TO 100
ADDR = ADDR + 3
PAUSE 100
I2CWRITE DPIN,CPIN,$A0,ADDR,[hr,mins,sec]
PAUSE 100
I2CREAD DPIN,CPIN,$A0,ADDR,[Ehr,Emins,Esec]
PAUSE 100
LCDOUT $FE,1,"RTC ", HEX2 hr, ":", HEX2 mins, ":", HEX2 sec
LCDOUT $FE,$C0,"EEP ",HEX2 Ehr, ":", HEX2 Emins, ":", HEX2 Esec
LCDOUT $FE,$90,"ADDR ", DEC ADDR
PAUSE 1000
NEXT I
'READ SAVED DATA
ADDR = 0
FOR I = 0 TO 100
ADDR = ADDR + 3
PAUSE 100
LCDOUT $FE,1,"READ SAVED "
NEXT I
GOTO RUN
Yes thats the chip I am using... 24LC1025 and the DS1337.
The memory is net getting full already, it shows screwed up time even in the beginning !!!
Ken
I mean the memory cannot be full. I am starting over each time the chip is power on and I just record a few few 'times' maybe 6 or 7. I must or ran 40 versions of this program. I cant find the problem :( I will use a different approach tonight
Just a thought...
Maybe being you are jumping 7 locations but writing to 3, when you go to read it is reading from locations that are empty.
Write_Address and bat are not starting from the same place?
Code:Write_Address = Write_Address +7
bat = bat + 7
Write_address is for recording, bat is for reading.
Lets say there are 3 reading:
first reading:
Read RTC then write at eeprom at 0
second reading:
Read RTC then write at eeprom at 7
third reading:
Read RTC then write at eeprom at 14
Then a show is made by putting C.7 to 0
Bat reads at 0
then bat reads at 7
then reads at 14.
A write is made again it is written at Write_address = 21
I am only using the first three anyway.
This is not the problem, the seconds for the first three reading are the same !!!!
eXAMPLE:
If I take 8 readings at 5 seconds interval, My results are that the first 3 are have the same time ie: 02:04:11 , the following 3 are: 02:04:27. last two are 02:04:38
Hola Dave,
I finally got the program to work like I wanted to, well almost. Its showing the same value twice. If I hit the record button. Then I hit the show button, then it will loop twice the show with the same time.. weird... it seems its doing the loop in red twice.. always.
Code:Mainloop:
if PORTC.6 =0 then
GOSUB READ_RTC
PAUSE 10
Endif
if PORTC.7 =0 then
if Write_Address = 0 then goto Mainloop
j = 0
For i=0 to (Write_Address / 3) -1
I2CREAD DPIN,CPIN,$A0,j,[sec,mins,hr]
PAUSE 10
LCDOUT $FE,1," Time ",DEC2 i
LCDOUT $FE,$C0,"WA ",DEC j," T:", dec2 hr, ":", dec2 mins, ":", dec2 sec
PAUSE 1000
j =j + 3
next i
Endif
GOTO Mainloop
READ_RTC:
pause 10
TempVal=hr
GoSub BCD_TO_BIN
hr=TempVal
TempVal=sec
GoSub BCD_TO_BIN
sec=TempVal
TempVal=mins
GoSub BCD_TO_BIN
mins=TempVal
yr = $3
mon = $5
date = $05
sec = $09
mins = $04
hr = $02
BCD_TO_BIN: ' Convert the BCD values into BIN
Temp1 = $0F & TempVal ' Clear off the top four bits
Temp1 = Temp1 Dig 0
Temp2 = TempVal >> 4 ' Shift down four to read 2 BCD value
Temp2 = Temp2 Dig 0
TempVal = Temp2 * 10 + Temp1
OK, I found it, changed the if then for BUTTON action with a 255 debounce cycle. works great now :))
Thanks Dave for all the time you spent with me on this.
I am glad to help. Good to see you got it.
