PID r outines and other thoughts...
Yes, I looked at Olsson's routines. I got distracted by the thought that my 16F887 is just not up to the task at hand.
I glanced through the MicroChip 18F PICs. My eye fell on the PIC18F46K20.
It comes in 40 pin PDIP format. That is good. It has lots more code memory space. It is on the list of devices that can be programmed by my PICKIT 2 and my Microcode Studio PICBASIC PRO combination. It must be bigger, faster, more capable than my 16F887. True? Which 18F should I choose. I have little to no sense of the differences.
Ken
Where my head is at this afternoon......
1. Although the SONAR only requires a 10microsec trigger pulse, at 1100 feet per second a five foot sound echo returns (order of magnitude) in a bit less that 10 millisec. I can not trigger both SONARs at the same time. I believe their echos would interfere. I certainly do not have to trigger these devices 50 times per second. Three or four times per second would be enough. This would give the velocity rate calculations more meaning. (Maybe I should make the SONAR activity interrupt dependent, not the PWM activity.)
2. The PIC needs to control the steering. It needs to keep the car traveling parallel to the side wall a given distance (desiredtrack) from that wall. It also needs to turn the car dramatically left when a (corner) wall appears inside a given distance (frontfree) in front. Both 'desiredtrack' and 'frontfree' are VAR WORDs - functions of the POT position (which also influences the speed of the car).
3. There is a totally separate algorithm controlling steering when the car is backing up due to a collision or a very near miss. Basicly steer right and back up a couple of feet then steer left and try to go forward.
4. If the steering were absolutely under control I feel the wheel speed could be pretty much left alone. Check the POT and make the PWM signal to the Electronic Speed Control proportional in seven stages.
5. My PIC really should have four pieces of data to work from.
A. Distance to the right wall.
B. Closing rate to the right wall.
C. Distance from an object in front.
D. Closing rate on the object in front.
If it had this information I think even I could code proportional feed back loops. Note two are rates. Each of these require two readings a known time apart, a subtraction process and some comparisons to fixed estimated values.
6. My model level car can be put under radio control merely by turning on the power to the ratio transmitter. It is selection which PWM signals (radio receiver sourced or PIC sourced) that is done by the DPDT coil driven relay switch. It is driving that relay switch coil that requires the SN7407 current driver.
7. I chose the HPWM to shape the steering and DC motor signals because by trial and error I found parameters that seemed to work at slower speeds. The signals continue no matter what the PIC code is doing. I do wonder whether I screw up a sequence each time I exercise a new HPWM command even if it is a repeat of the previous HPWM command. I do not understand the architecture details of HPWM command.
Ken
I just got the impression that.....
Scalerobotics wrote a while back:
I am not enough conversant with the various Microchip models to talk intelligently about what I need or don't need.
Ken
I have not played with oscillator speed.
My oscillator is 4Mhz (I think). I have done nothing to change it. Whatever it does naturally is what it is.
My guess is that SONAR triggering four times per second is sufficient.
Question: How do I create an interrupt every 1/4 second?
Ken
Thanks - you've got me started.
There are plenty of machine cycles to do the math work and the control decisions. I think the 5 millisec interrupt timing should give me accurate timing for the PWM signals. I have no idea how much noise there is in the SONAR responses. I want to space them further apart in time so the trends are clear. Four triggers for each SONAR per second is my first guess.
Now to bed. Thanks.
Ken
I need more reference information
Folks, I have been PBPing on a wing and a prayer (to quote an old WWII song). I need more
reference material. I compiled Mackrackit's code and got the following error. I do not know
where to go to chase it down.
Error 118 c:/~~~.asm 67: Overwriting previous address contents(2007)
Here's from the .asm file:
66 ASM?
67 __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
68
69 ENDASM?
Here's the spec WEB page.
Here's the WEB page for my SONAR SF05.
http://www.robot-electronics.co.uk/htm/srf05tech.htm
It says:
-10microsec trigger pulse
-produces an 8 cycle burst of 40khz sound (total duration 5millisec)
-can be triggered every 50millisec (20 per second)
-the beam pattern is conical.
Details! Details! Ain't technology grande!
Ken
That's kinda what I do...
cncmachineguy,
I sort of tried to do what you say:
goingforward:
HPWM 1,Straight,50
HPWM 2,Forward,50
keepgoingforward: '----Compare to right wall
IF rangeright > outertrack THEN
HPWM 1,QuarterRight,50
IF rangeright < desiredtrack AND oldrangeright < rangeright THEN
HPWM 1,Straight,50
IF rangeright > desiredtrack AND oldrangeright > rangeright THEN
HPWM 1,Straight,50
IF rangeright > desiredtrack AND oldrangeright < rangeright THEN
IF rangeright < desiredtrack AND oldrangeright >= rangeright THEN
HPWM 1,QuarterLeft,50
GOTO main
I have three degrees of turning in each direction. My "oldrangeright" WORD is the previous reading of that SONAR. What I had not done was make this state machine "math" actually proportional. My present thinking is that with finer control I would get smaller oscillations.
Ken
Here's a big issue with the 16F887 and PBP
I have avoided translating to digital any of my measurements. I have used > and <, but no actual arithmetic. To go proportional per the PID, requires that I do arithmetic. HEX or digital, that is the question. I'd like to think in digital, may I?
I'm going to reveal my age. I wrote in machine language on the IBM 370 back in the last century. Well back in the last century. Since then it has been C, C++, shell, tcl. I am used to having a large library backup and writing in a modular fashion. Now it is PBP. I think I need to know more about ASM coding and the architecture of the PICs. What is the easiest (best) way to learn?
Ken
I like the TIMER1 interrupt idea
cncmachineguy, TIMER1 interrupt with a carefully chosen pre-set sounds good to me. I am not succeeding in figuring out how to do it. Page 32 in the 887 spec talks about PIE1. Page 70 talks about T1CON. I do not know where to look for an example.
Is there a collection of PBP and ASM code samples? If so, where?
Ken
I have no idea what you guys are talking about.....
Right now I want an interrupt every 5 millisec. With a 1megahz clock and a 65356 counter, every 5 millisec is every 5000 ticks of that clock. cncmachineguy suggests that I generate an interrupt each time the clock gets down to 60356 by pre-setting the TIMER1 counter.
I understand that, but have not the faintest notion how to accomplish it. I have gone to Darrel Taylor's site. It is well written, but I do not see how it helps me.
Please help me get an interrupt every 5 millisec. Then I can try to figure out what code is needed to control the little car.
Ken
