HI2CREAD for 18Fs
I have seen several examples of hardware I2C slaves on this forum. When I try to implement them, they never work. Most of the code is for 16F devices, which I avoid like the plague. I'm sure the problem is in front of my keyboard, but realizing that doesn't get my project working.
Is anyone willing to provide me with a block of tested code for 18Fs?
I have an 18F252 as a I2C-Slave in PBP using ASM-code for the I2C-interrupts.
OK ?
I'm happy that you have that code... Would you care to share, or is it in some 'public' place already?
I'd also love to see that. Getting my hands dirty with HW I2C isn't quite as much fun as I though it might be...
bill.
Hello,
find attached my code (2 years old and not the best!).
I have removed the maincode.
I2C reads in bytes and fills up a buffer I2C_In.
The maincode generates data in a second buffer I2C_Out.
The incoming bytes are only single bytes, I don't know if the routine will manage more than 1 data in a message.
Just read the code and try to understand the statemachine of the I2C-hardware.
Thanks! And fortunately for me - my wife speaks German!
Here is a little program that drives a LCD as a I2C slave
'* Version : 1.0 *
'* Notes : PIC 18F4550 *
define LOADER_USED 1
define RESET_ORG 800h
define INTERRUPT_ORG 808h
DEFINE OSC 48
'**** LCD *******************************************************
'Set LCD Data port
DEFINE LCD_DREG PORTA
'Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 0
'Set LCD Register Select port
DEFINE LCD_RSREG PORTA
'Set LCD Register Select bit
DEFINE LCD_RSBIT 4
'Set LCD Enable port
DEFINE LCD_EREG PORTA
'Set LCD Enable bit
DEFINE LCD_EBIT 5
'LCD RW Register PORT
'DEFINE LCD_RWREG PORTB
'LCD read/write pin bit
'DEFINE LCD_RWBIT 5
'Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
'Set number of lines on LCD
DEFINE LCD_LINES 2
'Set command delay time in us
DEFINE LCD_COMMANDUS 2000
'Set data delay time in us
DEFINE LCD_DATAUS 50
' Initialize ports and directions
ADCON1 = $F 'port A digital
CMCON = 7 'PortA Digital
' PicBasic Pro I2C slave program
' Alias pins
scl VAR PORTB.1 ' I2C clock input
sda VAR PORTB.0 ' I2C data input
' Define used register flags
SSPIF VAR PIR1.3 ' SSP (I2C) interrupt flag
BF VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
R_W VAR SSPSTAT.2 ' SSP (I2C) Read/Write
D_A VAR SSPSTAT.5 ' SSP (I2C) Data/Address
CKP VAR SSPCON1.4 ' SSP (I2C) SCK Release Control
SSPEN VAR SSPCON1.5 ' SSP (I2C) Enable
SSPOV VAR SSPCON1.6 ' SSP (I2C) Receive Overflow Indicator
WCOL VAR SSPCON1.7 ' SSP (I2C) Write Collision Detect
' Define constants
I2Caddress CON $A2 ' Make our address 2
' Allocate RAM
result VAR BYTE ' ADC result
datain VAR BYTE ' Data in
dataout VAR BYTE[8] ' Data out array
readcnt VAR BYTE ' I2C read count
readcnt = 0 ' Zero counter
lcdout $FE,1," I2C LCD"
lcdout $FE,$C0," Ready"
trisb = %00000000
portb.0 = 0
portb.1 = 0
TRISB = %11111111
'pause 500
' Initialize I2C slave mode
SSPADD = I2Caddress ' Set our address
SSPCON2 = $0 ' General call address disabled
SSPCON1 = $36 ' Set to I2C slave with 7-bit address
GoTo mainloop ' Skip over subroutines
i2cslave: ' I2C slave subroutine
SSPIF = 0 ' Clear interrupt flag
IF R_W = 1 Then goto i2crd ' Read data from us
IF BF = 0 Then goto i2cexit ' Nothing in buffer so exit
IF D_A = 1 Then goto i2cwr ' Data for us (not address)
IF SSPBUF != I2Caddress Then goto i2cexit ' Clear the address from the buffer
readcnt = 0 ' Mark as first read
GoTo i2cexit
i2cwr: ' I2C write data to us
datain = SSPBUF ' Put data into array
lcdout datain
GoTo i2cexit
i2crd: ' I2C read data from us
IF D_A = 0 Then
EndIF
SSPBUF = dataout[readcnt] ' Get data from array
CKP = 1 ' Release SCL line
readcnt = readcnt + 1 ' Move along read count
GoTo i2cexit ' That's it
i2cexit:
mainloop: ' Main program loop
IF SSPIF = 1 Then ' Check for I2C interrupt flag
GoSub i2cslave
EndIF
GoTo mainloop ' Do it all forever
I think I found this on this forum.
And thanks from me as well. I'm certain I can get something working now.
Thanks for both those examples - that should help a lot.
bill.
