here is the code in its entirty
'Definitions'
DEFINE ADC_BITS 10 ' set number of bits in result
DEFINE ADC_CLOCK 3 ' set clock source
DEFINE ADC_SAMPLEUS 50 ' set sampling time for microseconds
'Definitions'
'Register Initializations'
ADCON0 = %10001011 ' set as right justified and turn on AD
ANSEL = %01001100 ' A to D on AN2 and AN3
CMCON = %00000111 ' set all pins to digital
TRISIO = %00011111 ' define Inputs and Outputs
GPIO = %00000000 ' set all pin states to off
WPU = %00000000 ' shut off weak pull ups
'Variables'
LOAD_OUT VAR GPIO.5
OFF_COUNTER VAR WORD
ON_COUNTER VAR WORD
AD_AN2_VALUE VAR WORD
AD_AN3_VALUE VAR WORD
i var word
K VAR WORD
'TEST_TRIGGER VAR GPIO.3
'TEST_COUNTER VAR WORD
CYCLE_COUNTER VAR WORD
OFF_TIME VAR WORD
'Variables'
INITIALIZE:
GOSUB READ_A_D_AN2
GOSUB READ_A_D_AN3
MAIN:
GOSUB ON_RUN
pause 10
GOTO MAIN
ON_TIME:
PAUSE 250 ' low end pause time (0.25 sec)
for i = 0 to ON_counter step 1 ' high end pause loop time (25 sec)
GOSUB READ_A_D_AN2
GOSUB READ_A_D_AN3
PAUSE 27
nEXT I
OFF_TIME_RUN:
' PAUSE 5000
for K = 0 to OFF_TIME step 1 'total pause loop time
GOSUB READ_A_D_AN3
GOSUB READ_A_D_AN2
GOSUB OFF_TIME_CALC
PAUSE 33
nEXT K
ON_RUN:
LOAD_OUT = 1
GOSUB ON_TIME
GOTO OFF_RUN
OFF_RUN:
LOAD_OUT = 0
GOSUB OFF_TIME_CALC
GOSUB OFF_TIME_RUN
GOTO INITIALIZE
OFF_TIME_CALC:
OFF_TIME = (CYCLE_COUNTER - ON_COUNTER) '+ 100
IF OFF_TIME < 120 THEN OFF_TIME = OFF_TIME + 150
if OFF_TIME = 1024 THEN OFF_TIME = OFF_TIME + 180
' if OFF_TIME > 2000 THEN OFF_TIME = OFF_TIME - 50
READ_A_D_AN2: 'used for ON Time Delay
PAUSEUS 50 ' wait 50 microsec
ADCIN 2, AD_AN2_VALUE ' read channel 2 to AD_AN0_VALUE
ON_COUNTER = AD_AN2_VALUE ' set counter to AD value
READ_A_D_AN3: 'used for Cycle Time Delay
ADCIN 3, AD_AN3_VALUE ' read channel 3 to AD_AN3_VALUE
CYCLE_COUNTER = AD_AN3_VALUE + 1024 ' set counter to AD value + 1024
