hello,is the 18f4620 suported by pbp?
thanks!
thanks!
You should first of all check on the manufacturers website for the latest release info... after all they're the folks that make it...
http://www.melabs.com/products/pbp.htm
and when you look down the list at the bottom of the page you then discover the words...
"PicBasic Pro Compiler now supports ALL Microchip PICmicro MCUs!"
And if you still don't believe it, look your favourite PIC up in the list provided.
Thanks...
my error was that microcode does not support it,but in the pbp folder i saw the definitions for this one...
...but i supose,and will try,to add it manually to the microcode definition list...
of course it will work. edit pic.ini file in the MCS folder, add your PIC and that's it that's all!!!
Thanks again!!
edited due to stupidity...........
and the programm did not run properly, its supposed to be in the main right before TRIS initialisation, isn't it? and another thin gdoes anyone here did a wireless connection using 4620 with rfm or a similar device?
Welcome to the forum,
Try starting a new thread with the problem you are having.
Post the troubled code and anything else that has to do with your project. Makes it a lot easier to help you.
Look at the threads linked here.
http://www.picbasic.co.uk/forum/showthread.php?t=11116
Many of the problems one has are answered there.
Good luck!!!
