How to know what pin triggered an interrupt?
A porta change interrupt occured! Cool!
But then in the INT handler I need to read the pin that triggered the int.
I could use:
IF (porta.0 == 1) ... (my code here)
IF (porta.1 == 1) ... (my code here)
(for all 6 pins... it will take a lot of space in my PIC memory)
Could I instead use something like:
If porta.0 = 1 then pin = 0
If porta.1 = 1 then ...
(for all 6 pins)
Then:
IF (porta.0(pin) == 1) THEN...
Is this syntax correct?
Isn't there an easier way to check what pin triggered the int? There is an INT flag that tells us there was a change on portA but no info on the pin that triggered the int...
