peak and hold fuel injector driver
Hi i am new to pic programming and i am wanting to make a PIC16f84A peak and hold injector driver circuit.
The injectors are .7ohm @ 12volts .7/12=17.14amps this current it too great. it only needs to saturate the injector for 500us and then osilate 5k-10k 50% duty for current limiting.
The Peak and Hold current look like this 17amp for 500us then 8amps
we need to current limit as the injector over heat with 17amp full saturation.
I am using PortA as 4 inputs and PortB as 4 Outputs.
But i need the pic16f84 to trigger the mosfet like this, Peak switch on for 500us then pwm 5k-10k hertz 50% duty for current limiting.
and when the signal is removed from input Port A input the output PortB must switch off and then wait for another input signal. all 4 Inputs and Outputs must be separate from each other.
any help will be much apreciated
thank you
Mark
i have leds flashing with inputs
Hi Dave i have all ready got a program setup that when you press a input button on portA it lights up an led on the output portB.
just need to do some peak and hold in the middle there thats what i am not to shure on.
Hi Melanie in a engine things happen pretty slow compared to electronics the pulse coming out of the Engine managment computer into the Injector driver box. When the engine is idling the ECU output is 1ms earth pulse and when the engines at 8000rpm it has a 8ms earth pulse, The milli second time is how long the injector is open for.
Melanie i am very keen about you idea or using discrete logic components for nanosecond timing. Could you maybe point me in the right direction with a diagram o somthing? that would be much apreaciated
Thank you
Mark
will have a look for some discrete
thank you for you information will have a look for some discrete components and also look at the bigger pic18f with PWM
please let me know if you find some part numbers on some discrete's
Thank you
Mark
MegaSquirt Electronic Fuel Injector Project
Here's a link that might be of interest,its not a pic but has schematics and components.
http://www.bgsoflex.com/megasquirt.html
