is there such a a thing as a Pulsin alternative?
i'm using a 12F675
right now i have a chunk of code
Radio is defined as an input,on GPIO.3 save pulse as "P"Code:radioIn:
PULSIN Radio,1,P
' With 20 meg osc pulse measures at 2 millisecs, With 4 meg osc pulse measures at 10 millisecs
PWM NpN, P, 100
goto radioin
PWM NpN is defined as an output on GPIO.2, use P as the PWM Duty, Cycle = 100 (also tried Cycle = 3, which had a better result)
goto = do it forever
OK, i am driving a 12V LED strip with a NPN Transistor. reading data from an R/C Airplane Receiver, this part works good
the problem is that the pulsin command takes up a LOT of time, enough time that you can see the flicker in the LED's (try it it's enough to give you a seizure).
is there an alternative to Pulsin that maybe can do its job a little faster?
or is this where you are better off to find a chip with HPWM and go that route?
thank you in advance
