Hi, i want to transfer some data from 3 micro controllers to one micro. i don't want to use wireless transmission. the distance between micro controllers are at least 10 meter. i use PIC16F877A and picbasic pro 2.43, could you help me?
Hi amindzo,
look at this link, I bought several of this authors books, and would again.
http://www.lvr.com/serport.htm#my_example_code
Hi,my friend suggest that you use a multi cable to connect one port to another port of main micro(8 wire,for example PORTB of micro 1 to PORTC of main micro) and use PEEK and POKE instruction. you put one byte on a port and read it from main micro and you should make a time program to read data on time.
but it is not a good method. it's need a lot of wire and the distance can effect on the voltage,current and also we have noise.
what about using serin and serout instructions and a shield cable?
That'll work great...
http://en.wikipedia.org/wiki/EIA-485
if i want to use serin and serout instructions, can i connect(for example) PORTB.0 of micro 1 to PORTC.1 of main micro with wire directly?(with 10 to 20 meter distance)
Hi, which cable i should use for this application to avoid noise problems and if i want to use MAX232 how should i connect it to microcontroller ? could you show me the diagram and the code in picbasic pro with serin and serout instructions?
Anything else?
http://www.picbasic.co.uk/forum/showthread.php?t=1498
