External Interrupts Vs. RB/KBI Interrupts?
I'm laying out a design with a 18F45K20. What is the difference between the standard "External Interrupts" INT pins, and the other PORTB "Interrupt on Change" pins.
There are INT0, INT1, and INT2 on RB0, RB1, and RB2.
There are also KBI0, KBI1, KBI2, and KBI3 on RB4, RB5, RB6, and RB7.
The data sheet seems to indicate they can each wake the processor from sleep.
I have 3 inputs I need to handle - a high pulse from another processor, a tilt sensor, and a push button.
I want to be able to use Darrel's Instant Interrupts to handle any of the 3 inputs, I would also like to use all 3 inputs to wake the processor from sleep. Ideally, I'd like to be able to tell the source of the input after the interrupt occured.
Does it really matter what pin (an INT pin or a KBI pin) I use for these inputs?
Thanks!
